I have a 3400 out of an 02 monte carlo that will be going into my 89 z24.
I finally found my extra 3.1 fuel injector harness but the insulation on the wires is brittle and cracks whenever you bend the wires. I figured that i would just splice the weather pack end of the 3.1 harness onto the 3400 harness(already removed map sensor, cts, and cam sensor plugs) as i want to use the multec 2 injectors(I plan on getting a chip burned). I know that the pink/black wires on the 3.1 harness are the 12v and the green and blue wires are the ground from the ecm.
Here's my question. each injector on the 3400 harness has an orange wire going to it. then there are various colored wires going to each injector. are the orange wires the 12v and the various color wires ground?
anybody else done there harness like this?
Thanks,
Stephen
Thanks,
Stephen
