Just wondering if Crane Gold race rockers from a 4.3L 90* v6 could work with the gen 2 aluminum heads or even gen 3 aluminum heads(of course with a stud conversion cause these come with 3/8"). Thanks for looking.
Will these work?
Will these work?
98 camaro swapping in lz9 th400 setup
LZ9 specs: (Subject to Change work in progress)
4.0L(after bore 3.917 and stroke 3.3485),carrillo sbc rods(narrowed),wiseco custom forged pistons 8.5:1 CR, TCE Double Roller timing chain, gen 3 cam, P&P heads, headers 1 3/4 primaries into 3-1 collector, and going to run ms2.Tags: None
Heres the exact info on these rockers http://www.cranecams.com/?show=brows...umber=10758-16. From the description it seems like they should work fine other than needing possibly some clearencing, and the stud conversion.98 camaro swapping in lz9 th400 setup
Yea they will work. No clearancing is required on Gen I or Gen II. Gen III will require intake grinding.
I am guessing you are getting these rockers used? Because if you are buying new I would suggest the COMP Pro Magnums because they have a much smaller back section and I am willing to bet they will not require any clearancing on Gen III1993 EXT. CAB, 3.4L V6 TBI, 5spd manual. Sonoma
Yea I was looking at both sets and I have found a set of each used. I was just looking into getting the gold race because they have the full roller fulcrum.98 camaro swapping in lz9 th400 setup
So do Pro Magnums http://www.compcams.com/Technical/Cu...g/HTML/311.asp1993 EXT. CAB, 3.4L V6 TBI, 5spd manual. Sonoma
