Well, I finally got the set. It is part number 9-3137. Cool thing is that it does have an IWIS chain. Not sure if they have always come with one or not. Bad thing is, I'm not certain it is going to work on a 3400.
The stock timing set has a raised piece that sits inside of the cam thrust plate. The cloyes cam gear does not. The only way to mount it would be to eliminate the thrust plate, and modify the cover and use a cam button.
Anyone else ever do this? On a 3400?
See the following pictures:
