I know this has been beat to death, but I can't find any part numbers for the spring seats. These are going on gen 2 heads. I'm planning on ordering the LS6 springs from Lingenfelter,the Comp valve locks and retainers from the store, and if I can find a part number, the seats from GMPD. If not, looks like I'll be hitting up the F-body/GTO boards.
This should be all I need, correct? I've read about shims but everyone here has gen 3 heads so it's hard to find specific info relavent to me.
Another quick question, while I'm here. Crane H260 is my cam, 3100 stamped 1.6 rockers. With these springs, should I worry about excessive lobe wear with gen 2's wonderful oiling system? That was the reason I had to start rebuilding this motor in the first place.. lobe 10 on the stock cam bit the bullet. I plan on adding an aux oiler setup for some problem lobes on the cam to help out, but if necessary I'll make sure it's hitting all of the lobes.
