A while back, I read an article in the engine swaps section about a 3400 block with fiero heads and intake swapped into a fiero. Does anyone know where I can find it now?
Where is the iron head 3400 engine swap article?
Really? Why would anyone want to do that... Anyway, I'll see if I can find it from the old site backup.-Brad-
As I recall, it was the last engine swap listed in the "engine swap" section. I believe it was titled "3400 in a fiero".Originally posted by bszopiReally? Why would anyone want to do that... Anyway, I'll see if I can find it from the old site backup.
I am not sure why the author chose that combination. I have embarked on this swap because it represents the best possible engine that can pass a visual inspection in California. From the top it looks identical to the stock 2.8.
But it has .6 extra liters of displacement, roller cam, cross bolted mains and cast aluminum oil pan.
