How to replace the alternator Alternate Text
  • How to replace the alternator Alternate Text
    Special Tools Needed:
    Tie rod separator, Good hydraulic jack, set of metric sockets that has 15mm, 16mm, 18mm
    Intro
    Before you start find a day when you have about four to five hours to kill.
    Some things you may want to replace while here. You may have to get these prior to starting.
    1. Oxygen sensor. It's cheap and easy to get to while here.
    2. Donut gasket in the head pipe in the exhaust. Order it before you get under the car. Mine had a small leak. The bolts had soot all over them.
    Instructions
    1. Disconnect the battery. I usually just remove the air filter box. Two bolts o*n each side of the box, o*ne screw around the air intake hose and remove the AIT plug connection. Then pull it out.
    2. Remove the antifreeze overflow bottle. o*ne screw and o*ne speed nut then remove the overflow hose and pull straight up.
    3. Remove accessory drive belt.
    4. Remove the nut that holds the power steering hose clamp to the top alternator bolt. o*ne nut.
    5. Jack up the car real high and remove both front tires.
    6. Passengers side of the car at the wheel well remove the rubber dust cover from the firewall and from around the drive axle.
    7. Remove the Passengers side tie rod end from spindle.
    8. Loosen the front engine cradle bolts. Place a jack under the rear of the engine cradle and remove rear engine cradle bolts.
    9. Lower the cradle about an inch or two then go to drivers side and remove the bolt in the steering knuckle.
    10. Lower the engine cradle the rest of the way until the top dog bone holds up the cradle.
    11. At this point crawl under the car and get under the back of the oil pan.
    12. Remove the lower alternator bolt, 13mm, and the upper alternator bolt, 10mm, from the passeenger's side of the the car.
    13. There is a piece of black ductwork at the bottom of the pan. To remove it there is a snap clamp up in the dark hole where the alternator is. It is hard to get loose. Then pull the duct out.
    14. When you get it off you can get the rest of the alternator bolts out and it will drop down.
    15. Remove the cables from the back of the alternator and go to the Passengers side of the car.
    16. There should be just enough room for the alternator to come out. You may have to turn it, roll it and possibly even remove the clamps from the AIR pump lines to get some more room but it will come out.
    17. While under if you decide, pull two bolts to the head pipe and let it drop
    18. Get a wrench that will fit the O2 sensor and remove it and install the new.
    19. Replace the gasket to the head pipe and bolt it back o*n. This is difficult and you may need to raise the cradle up some to get the bolts in.
    20. To get it back try to reverse this. o*ne note don't forget the steering knuckle when you raise the cradle back up.
      Posting comments is disabled.
    Article Tags
    There are no tags yet.
    Latest Articles
    • LQ1 Service Bulletin 57-61-09 Lifter tick (cold)
      by Schurkey
      Dug up the GM Service Bulletin for "Lifter tick when cold", 57-61-09. '91 to '95 LQ1 (VIN X) (mymonte.com is gone) The parts kit has been discontinued by GM long ago. My quest was to find sources for those parts; and complete the procedure on my '93 Lumina Euro 3.4 which was torn apart to replace the rear head gasket. There are three critical part numbers in the GM service kit (aside from gaskets and O-rings) required to perform this operation. Two of the three are readily available in the afterm...
      03-02-2012, 01:48 PM
    • 3.4 DOHC Heads on a 3x00 Block
      by bszopi
      Several people have talked about the possibility to use the 3.4 DOHC heads on the 3x00 engines. Some for performance, and some for replacment, where getting a 3.4 DOHC block might be difficult, but getting a 3400 (or even a 3100) block might be easier to come by. For these test fittings, I used a 1994 3.4 DOHC BLOCK, a 1994 3.4 DOHC REAR head, a 1999 3100 SFI BLOCK, and a 1996 3100 SFI head. This article is broken into 3 sections. The first section is BASIC COMPARISONS where I compare the BLOCK o...
      01-20-2011, 11:08 AM
    • 3.4L (DOHC) Specifications
      by bszopi
      06-15-2010, 04:56 PM
    • OBD2 Tuning 3.4 DOHC
      by Dave96z34
      The 97 4T65 in the Monte Carlo is almost bullet proof. I have been beating the crap out of my reman with my blower now for 2.5 years of daily driving vs the 60 NA that I couldn't get 1 year out of. 4 Trans in 50K miles. I'm a violent offender. Overfilling and royal purple atf are my secret. DHP will do 96 and 97 DOHC tuning, HPTuners only works with the 97 computer. 96 can not change line pressure, 97 can. 97 bin is double in size of the 96 bin. They changed every thing and it has every ...
      04-17-2010, 03:53 AM
    • 3.4 DOHC Pistons
      by SappySE107
      Here is the TRW catalogue spec sheet for the 91-95 as well as the 96/97 pistons.
      TRW 3.4 DOHC Pistons
      Silvolite 3.4 DOHC Pistons Notice that the 96-97 pistons don't have as much compression distance but also have a dome to them. I dont know the exact amount of compression loss you will get when using these pistons with the 91-95 heads, but it goes against the common belief that 96 pistons raise compression. The Silvolite pistons are the EXACT pistons used in the 91-
      04-14-2010, 12:23 AM
    • 96/97 3.4 DDOHC Intake Manifold Swap for 91-95 Engines
      by OldSkoolGP
      Pictures can befound here * Need to find this album *
      http://60degreev6.com/gallery/browseimages.php?c=27 Having just completed this swap myself and being MORE than impressed with the results, I felt the need to write up how to properly do this swap so everyone else can do it easily: First off, here are the major components you will need from your donor motor: Upper Intake (Plenum) Lower Intake and fuel rail ’96 Rear Cam Carrier Cover (Valve Cover) Intake pipe Throttle Bo...
      04-14-2010, 12:20 AM
