Using GM Top Engine Cleaner
  • Using GM Top Engine Cleaner
    The basis for cleaning the top end of your engine is pretty simple. The EGR system recirculates exhaust gases which deposit carbon all over your intake manifolds and the intake port on the heads. The backside of the intake valve is also a concern as the carbon not only attracts the fuel, but also changes/lowers your airflow. Efficiency and horsepower are lost over time.
    To use the GM top end cleaner, you can use either the spray or the liquid, though I prefer the liquid.
    First, start in a well ventilated area. This is going to cause quite a smoke show
    Let the engine idle to warm up, or if already warm, let it sit for a minute or 2 at idle to heat up the entire engine. Then, using a smaller vacuum line, like the one going to the fuel pressure regulator, stock a vacuum line into the bottle of cleaner. You will need to hold the throttle open a little more so the engine doesn't die. You need almost all of the can to go through the engine. Before its completely gone, either close the throttle and hope the engine stops as well, or have someone else turn the key off. Reconnect the vacuum line to whatever you took it off of and let the engine sit for 10 minutes.
    Starting the car/truck after 10 minutes is going to be difficult. It will probably turn over a bit before it ever catches, and then it will probably run a little rough. You need to rev it up a little and get it so it will idle. Then, after its ok for idle, you need to drive around to clean it all out. This will cause a lot of smoke still so hopefully you can do this somewhere without too much traffic. Varying the throttle and increasing the max % of throttle over time (say a couple minutes) will eventually get it all cleaned out and running better.
    There are other methods to this so if you would like to add anything please leave a comment.
      Posting comments is disabled.
    Article Tags
    There are no tags yet.
    Latest Articles
    • Saginaw power steering pump - Resealing....
      by davida1_hiwaay_net
      Hi folks! Sorry I've been offline for quite some time. Been working overseas and it's been crazy! Anyway I finally got around to fixing the leaking steering pump on my 84 Century. As far as I know the PUMP is original to the 1987 year engine (which i bought as a core engine). For quite some time, it has leaked oil slowly, so that if the car sits for a month or so, all the oil is gone out of the steering pump. So, today I fixed it. I was quoted a high sum of money for a "rebuilt" pump of dubio...
      03-18-2013, 06:25 PM
    • How to read turbo maps...
      by Driver_10
      There have been a couple of guys who wanted to know how to read a compressor map. Hopefully, I haven't made any mistakes this time (unlike the last) and this will prove to be useful to you in your understanding of a compressor map. Reading a turbo map isn't as difficult as it looks. The map displays 4 key pieces of information. A. It displays the pumping efficiency of the compressor (meaning the amount of actual air that it pumps in contrast to the amount of heat that's created while wasting e...
      11-27-2011, 09:01 PM
    • Tire/ wheel info
      by z34phoenix
      General Tire/Wheel info:
      Tire Calc: http://www.miata.net/garage/tirecalc.html
      Alt Tire Calc: http://www.1010tires.com/TireSizeCal...?action=submit
      Tire Info: http://www.discounttiredirect.com/di...foTireMath.jsp 5x115 The 1ST # is the number of lugs. The 2ND is the spacing between the lugs, measuring center point of the lug to the next lug. have heard that 5x114.3 from something like a mustage will work. Our wheels have an offset of +40. Offs...
      09-10-2011, 08:58 AM
    • Cruise Control Switch Repair
      It seems that ALL the cruise control stalks you find at the JY nowadays are non-working. The Cruise switch doesn't work. Tired of paying $40 for a new stalk, I decided to dismantle and attempt repairs to what I had.
      The stalk is glued together and there will be some minor cosmetic damage during the dis-assembly, but if you file down the burs before gluing it back together it is not serious.
      This is the stalk I am going to repair.
      First, separate it at the join...
      07-21-2011, 09:09 PM
    • V5 A/C compressor tear down / re-seal...
      Pictures of tear down and re-seal of Harrison V5 air conditioning compressor. These are very common on the 60°V6 engines. They are very costly as a re-manufactured unit. The parts to re-seal them are about $30. I did this write-up for another forum but figured it would have interest here. I started with this unit. I had it on my 1972 Chevy Nova until it started leaking around the housing o-rings. It still cooled fine, it would just lose freon over about a 2 month period. It will go on a 2.8 car...
      07-17-2011, 07:47 AM
    • WOT-Tech pistons and the CR Calculator
      by bszopi
      With all of the different top-end swaps and bottom-end builds out there, I was talking to Ben at WOT-Tech about the Diamond pistons and how different setups would affect the compression ratios (CR) of the pistons he was offering. I wanted to pass this piston information on to the users so that they could then determine what their final CR would be with any setup. Due to marginal sales, WOT-Tech has decided to no longer list or stock specific CR pistons anymore. What does this mean to everyone? It means you can tailor the pistons to suit your specific application, no matter what components you are using. ...
      01-24-2011, 01:21 PM
