V5 A/C compressor teardown / re-seal...
  • Page 2
  • V5 A/C compressor tear down / re-seal...
    Now use the puller on the clutch magnet.
    OFF with the clutch magnet!
    Nasty looking. Will need to clean this SPOTLESSLY clean before opening it.
    After a few minutes with the Purple Soap and pressure washer, it's all clean!
    Remove the external parts. Take out the compensating valve and the oil plug.
    Remove the bolts that hold the compressor together.
    • Tbay99Venture
      Tbay99Venture commented
      Editing a comment
      +10 on the problem aligning the pistons if they pop out. I did that once with a Sanden. My biggest problem comes back to keeping everything clean. He makes it look easy, for some of us that's 100% attention to keep things clean. I think 60degreesBelow0 mentioned some nitrogen flushing tips, maybe I'm confusing posts. That would be helpful to link from this.
      bszopi commented
      Editing a comment
      Pics are now hosted here. Clicking on the pictures will show the full size version, if needed. I also split it up into multiple pages so make load time faster, as well as making it easier to follow.
    • davida1_hiwaay_net
      davida1_hiwaay_net commented
      Editing a comment
      Thanks for hosting the pictures here! My home computer has just a limited number of connections it can handle.
    Posting comments is disabled.
Article Tags
There are no tags yet.
Latest Articles
  • Saginaw power steering pump - Resealing....
    by davida1_hiwaay_net
    Hi folks! Sorry I've been offline for quite some time. Been working overseas and it's been crazy! Anyway I finally got around to fixing the leaking steering pump on my 84 Century. As far as I know the PUMP is original to the 1987 year engine (which i bought as a core engine). For quite some time, it has leaked oil slowly, so that if the car sits for a month or so, all the oil is gone out of the steering pump. So, today I fixed it. I was quoted a high sum of money for a "rebuilt" pump of dubio...
    03-18-2013, 06:25 PM
  • How to read turbo maps...
    by Driver_10
    There have been a couple of guys who wanted to know how to read a compressor map. Hopefully, I haven't made any mistakes this time (unlike the last) and this will prove to be useful to you in your understanding of a compressor map. Reading a turbo map isn't as difficult as it looks. The map displays 4 key pieces of information. A. It displays the pumping efficiency of the compressor (meaning the amount of actual air that it pumps in contrast to the amount of heat that's created while wasting e...
    11-27-2011, 09:01 PM
  • Tire/ wheel info
    by z34phoenix
    General Tire/Wheel info:
    Tire Calc: http://www.miata.net/garage/tirecalc.html
    Alt Tire Calc: http://www.1010tires.com/TireSizeCal...?action=submit
    Tire Info: http://www.discounttiredirect.com/di...foTireMath.jsp 5x115 The 1ST # is the number of lugs. The 2ND is the spacing between the lugs, measuring center point of the lug to the next lug. have heard that 5x114.3 from something like a mustage will work. Our wheels have an offset of +40. Offs...
    09-10-2011, 08:58 AM
  • Cruise Control Switch Repair
    It seems that ALL the cruise control stalks you find at the JY nowadays are non-working. The Cruise switch doesn't work. Tired of paying $40 for a new stalk, I decided to dismantle and attempt repairs to what I had.
    The stalk is glued together and there will be some minor cosmetic damage during the dis-assembly, but if you file down the burs before gluing it back together it is not serious.
    This is the stalk I am going to repair.
    First, separate it at the join...
    07-21-2011, 09:09 PM
    Pictures of tear down and re-seal of Harrison V5 air conditioning compressor. These are very common on the 60°V6 engines. They are very costly as a re-manufactured unit. The parts to re-seal them are about $30. I did this write-up for another forum but figured it would have interest here. I started with this unit. I had it on my 1972 Chevy Nova until it started leaking around the housing o-rings. It still cooled fine, it would just lose freon over about a 2 month period. It will go on a 2.8 car...
    07-17-2011, 07:47 AM
  • WOT-Tech pistons and the CR Calculator
    by bszopi
    With all of the different top-end swaps and bottom-end builds out there, I was talking to Ben at WOT-Tech about the Diamond pistons and how different setups would affect the compression ratios (CR) of the pistons he was offering. I wanted to pass this piston information on to the users so that they could then determine what their final CR would be with any setup. Due to marginal sales, WOT-Tech has decided to no longer list or stock specific CR pistons anymore. What does this mean to everyone? It means you can tailor the pistons to suit your specific application, no matter what components you are using. ...
    01-24-2011, 01:21 PM
