Install and tighten bolts, and your compressor should look like this.
Remove old o-rings from compensating element.
Install new o-rings on the compensating element.
Lube it with silicone paste and pop it in! Then place the snap ring in place.
Now for the shaft seal. First, install the o-ring into the spotlessly-clean compressor neck.
Now, take the CLEAN shaft seal thimble and install on the shaft.
