4T65E Hardened 4th hub & solenoid upgrade
Created by:
Tbay99Venture
- Published: 07-28-2010, 04:06 AM
- 1 comment
- Closing Up
4T65E Hardened 4th hub and solenoid upgrade
CLOSING UP
Place gasket onto transmission. Make one last check of wiring, bolts, confirm cover is as clean as possible and slip inside wheel opening and onto transmission.
Check the gasket is aligned correctly between case and cover. You may want to put anti-seize compound on the threads of the Torx bolts. Begin installing bolts and tighten all (even the Torx bolts) to 18 ft-lb/25 Nm.
Attach engine mount bracket to cover. Torque to ? 35 ft-lb is used for other bolts, Haynes says 70 ft-lb. Seriously?
Tags: None
Posting comments is disabled.
Categories
Article Tags
There are no tags yet.
Latest Articles
by robertisaarThe following pages contain information on specific transmission models from the 4T60, 4T60E and 4T65 family(4T40/4T45 and 4T80 information may be in the works, stay tuned). For now, it is NOT an all-inclusive list, but any missing information would be appreciated.
Miscellania:
4T60E Differentials with an asterisk are "fine pitch" final drives. Sun gears, internal ring gears, and pinion gears are NOT interchangeable with other final drives.
4T65E with "IMS" have the newer type of s...
Channel: Transmissions
by onefastV6So you have significantly modded your engine and now your transmission seems to be the weak link of your build. You have a few options to upgrade the stock 4T45E transmission which can be rather costly, or you can swap to the stronger 4T65E series transmission which seems to be uncharted territory for many. The purpose of this article is to provide a little more insight on what it will take to swap a 4T65E transmission into your 99+ N-body. ...
09-20-2010, 08:36 PM -
by bszopi4T40-E/4T45-E Automatic Transaxle Unit Repair
NOTE: Click on images to see a full-size view.
Fastener Tightening Specifications
End Play Specifications
Reverse Clutch Backing Plate Specifications
On-Vehicle
General Specifications
Range Reference
Shift Solenoid Va...-
INTRO This is a guide on how to service your transverse automatic transmission without a lift. All work is done with the vehicle on jack stands. Once the cover is removed the valve body is left attached to the channel plate. This assembly can then be moved to a workbench for easier servicing if valve body work is in your plans. In any case the transmission drive chain, pump, 4th gear assembly and many other parts can be repaired or upgraded at this time. In the description below the term "c...
Kristopher Gerbracht
