4T65E Hardened 4th hub & solenoid upgrade
  • 4T65E Hardened 4th hub and solenoid upgrade
    INTRO
    This is a guide on how to service your transverse automatic transmission without a lift. All work is done with the vehicle on jack stands. Once the cover is removed the valve body is left attached to the channel plate. This assembly can then be moved to a workbench for easier servicing if valve body work is in your plans. In any case the transmission drive chain, pump, 4th gear assembly and many other parts can be repaired or upgraded at this time.
    In the description below the term "channel plate" is used, sometimes the term "case cover" is applied to the same part. The term "cover" applies to the large casting on the driver's side that seals the transmission and holds the engine mount bracket. The term "pan" applies to the oil pan on the bottom of the transmission.
    Parts on Hand:
    • Upgraded solenoids
    • ATF: 10 qts
    • Hard parts (4th hub, shift kit, accumulator upgrade, etc.)
    • Cotter pin (ball joint castle nut)
    • Transmission assembly gel or Vaseline
    • Seals: shaft and lathe cut driver's side case seal.
    Special Tools:
    • 33mm/34mm deep socket -- depends on your spindle nut
    • Engine support beam
    • Strong T-40 Torx(R) bit
    • Cold chisel
    • Heavy hammer/mini sledge
    • Small & medium pry bars
    • Large drift pin or scrap cylinder head bolt
    • Soft mallet
    • Scrap wire to suspend brake caliper
    • Kristopher Gerbracht
      Kristopher Gerbracht commented
      Editing a comment
      I own an 85 6000 STE with the 'W' engine and TH 125 C. I did not see any specific date for the 'W' engine or the TH 125 C. Will I find any information somewhere else?
    Posting comments is disabled.
Article Tags
There are no tags yet.
Latest Articles
  • 4 Speed Automatic Transaxle Info
    by robertisaar
    The following pages contain information on specific transmission models from the 4T60, 4T60E and 4T65 family(4T40/4T45 and 4T80 information may be in the works, stay tuned). For now, it is NOT an all-inclusive list, but any missing information would be appreciated. Miscellania: 4T60E Differentials with an asterisk are "fine pitch" final drives. Sun gears, internal ring gears, and pinion gears are NOT interchangeable with other final drives. 4T65E with "IMS" have the newer type of s...
    10-08-2010, 01:48 PM
  • 4T65E and 4T65E HD (99+) N-Body Swap
    by onefastV6
    So you have significantly modded your engine and now your transmission seems to be the weak link of your build. You have a few options to upgrade the stock 4T45E transmission which can be rather costly, or you can swap to the stronger 4T65E series transmission which seems to be uncharted territory for many. The purpose of this article is to provide a little more insight on what it will take to swap a 4T65E transmission into your 99+ N-body. ...
    09-20-2010, 08:36 PM
  • 4T4x-E Mechanical Specifications Information
    by bszopi
    4T40-E/4T45-E Automatic Transaxle Unit Repair
    NOTE: Click on images to see a full-size view.
    Fastener Tightening Specifications
    End Play Specifications
    Reverse Clutch Backing Plate Specifications
    On-Vehicle
    General Specifications
    Range Reference
    Shift Solenoid Va...
    08-18-2010, 08:25 PM
    by Tbay99Venture
    INTRO This is a guide on how to service your transverse automatic transmission without a lift. All work is done with the vehicle on jack stands. Once the cover is removed the valve body is left attached to the channel plate. This assembly can then be moved to a workbench for easier servicing if valve body work is in your plans. In any case the transmission drive chain, pump, 4th gear assembly and many other parts can be repaired or upgraded at this time. In the description below the term "c...
    07-24-2010, 09:59 PM
