4 Speed Transaxle Info
  • 1999
  • 4 Speed Automatic Transaxle Info
    1999 - 4T60E
    Model Code Motor and Platform Differential Ratio Sprocket Ratio Final Drive Ratio VSS Reluctor Stall Speed
    9AHW *3.29 35/35 3.29 30
    1999 - 4T65E
    Model Code Engine Platform Differential Ratio Sprocket Ratio Final Drive Ratio Converter Code Converter Diameter K-Factor (Stall) IMS
    9APB 3800 V6 Buick Regal/Century 3.05 35/35 3.05 JZFM 258mm ??? No
    9BCB 3400 V6 Venture, Trans Sport, Silhouette 3.29 35/35 3.29 FLQB 245mm 163 No
    9BCB 3800 V6 Pontiac Grand Prix 3.29 35/35 3.29 FLQB 245mm 163 No
    9CMB 3800SC V6 Buick Riviera 3.29 37/33 2.93 JSFM 258mm 133 No
    9CRB 3800 V6 Olds Intrigue 3.05 35/35 3.05 FLQB 245mm 163 No
    9FAB 2.5L Buick (China) 3.29 33/37 3.69 FDHB 245mm 180 No
    9FCB 3800SC V6 Buick Park Avenue/Ultra 3.29 37/33 2.93 JSFM 258mm 133 Yes
    9FDB 3800SC V6 Olds 88, Pontiac Bonneville 3.29 37/33 2.93 JSFM 258mm 133 No
    9FFB 3800 V6 Buick Park Avenue/Ultra 3.05 35/35 3.05 JSFM 258mm 133 Yes
    9FMB 3.0L Buick (China) 3.29 35/35 3.29 FDHB 245mm 180 No
    9KAB 3800 V6 Chevrolet Police/Taxi 3.29 35/35 3.29 FLQB 245mm 163 No
    9THB 3800 V6 Chevrolet Monte Carlo/Lumina 3.29 35/35 3.29 FLQB 245mm 163 No
    9TNB 3800 V6 Buick LeSabre, Olds 88, Pontiac Bonneville 3.05 35/35 3.05 FLQB 245mm 163 No
    9XAB 3800SC V6 Buick Regal, Pontiac Grand Prix 3.29 37/33 2.93 JTFM 258mm 155 No
    9YCB 3.5L DOHC Olds Intrigue 3.29 35/35 3.29 JSFM 258mm 133 No
    9YFB 3800 V6 Buick LeSabre, Olds 88, Pontiac Bonneville 2.86 35/35 2.86 FLQB 245mm 163 No
    • jschmieding
      jschmieding commented
      Editing a comment
      can you switch out the IMS between a 99 and a 00
    Posting comments is disabled.
Article Tags
There are no tags yet.
Latest Articles
    by robertisaar
    The following pages contain information on specific transmission models from the 4T60, 4T60E and 4T65 family(4T40/4T45 and 4T80 information may be in the works, stay tuned). For now, it is NOT an all-inclusive list, but any missing information would be appreciated. Miscellania: 4T60E Differentials with an asterisk are "fine pitch" final drives. Sun gears, internal ring gears, and pinion gears are NOT interchangeable with other final drives. 4T65E with "IMS" have the newer type of s...
    10-08-2010, 01:48 PM
  • 4T65E and 4T65E HD (99+) N-Body Swap
    by onefastV6
    So you have significantly modded your engine and now your transmission seems to be the weak link of your build. You have a few options to upgrade the stock 4T45E transmission which can be rather costly, or you can swap to the stronger 4T65E series transmission which seems to be uncharted territory for many. The purpose of this article is to provide a little more insight on what it will take to swap a 4T65E transmission into your 99+ N-body. ...
    09-20-2010, 08:36 PM
  • 4T4x-E Mechanical Specifications Information
    by bszopi
    4T40-E/4T45-E Automatic Transaxle Unit Repair
    NOTE: Click on images to see a full-size view.
    Fastener Tightening Specifications
    End Play Specifications
    Reverse Clutch Backing Plate Specifications
    On-Vehicle
    General Specifications
    Range Reference
    Shift Solenoid Va...
    08-18-2010, 08:25 PM
  • 4T65E Hardened 4th hub and solenoid upgrade
    by Tbay99Venture
    INTRO This is a guide on how to service your transverse automatic transmission without a lift. All work is done with the vehicle on jack stands. Once the cover is removed the valve body is left attached to the channel plate. This assembly can then be moved to a workbench for easier servicing if valve body work is in your plans. In any case the transmission drive chain, pump, 4th gear assembly and many other parts can be repaired or upgraded at this time. In the description below the term "c...
    07-24-2010, 09:59 PM
