Gen2 to Gen3 Top-End
    • 9190
    This is an article that we have had on here for quite some time, and is probably the original 3x00 hybrid write-up. It needs some updating, so I would like to get peoples' input on it. If you know of other issues, or can provide more explanation of certain areas, post it here. Also, I would like to add images to the write-up as well. I know there are some images scattered around 60V6.com that will work well on different areas, but the more images to choose from, the better.
  • no_doz
    • Sep 2005
    • 912
    id like to know if the pushrod ends need to be different since 3x00's are roller setups (i believe) & the gen 2's arent-does this mean the pushrod end that makes contact with the lifters needs to be roller or is the 3x00 roller part just for the cam & pushrod ends that make contact with the cam in the 3x00's?
      What????? Read how pushrod engines work and that will answer your question :P
      The length is the only thing to worry about.
      • no_doz
        • Sep 2005
        • 912
        u need to take it easy-i know perfectly well how they work but ive never worked on something with roller-anything-so dont insult what i do know just because i dont know as much as you, its pretty shitty that youll go out of your way to post something nasty towards me without even attempting to understand what i was asking.
        what i was asking is arent the pushrod ends different due to the fact that the 3x00 engines have roller components-whereas the older engines do not-wouldnt this mean that the pushrod ends that have to make contact with the 3x00 lifters need to be different due to the roller aspect?
          • 9190
          No. I will try to find pics to explain...
          • sprucegagt
            Old School KI
            • May 2005
            • 703
            If your post had even the illusion of making sense, then you wouldn't have this problem.
            As for a short answer to your question, NO. Pushrods have always had either a ball or cup end. Roller anything, makes no difference.
            Your local OBDII moderator
            2000 Grand Am GT w/ WOT parts
              • 9190
              Ok, here we go...
              3x00 roller rockers and pushrods
              3x00 roller lifters
              Pushrod sits in the end (pocket) of the lifter. Roller is on the cam end. Pushrod sits in the end (pocket) of the rocker as well. Stock 3x00 roller rockers are just roller fulcrum. If they were full roller, then they would have a roller tip on them as well, but that is on the valve/spring end of the rocker. Pushrod end is still a pocket.
              Full roller rocker - notice pushrod pocket and roller tip:
              • no_doz
                • Sep 2005
                • 912
                now thats what im talkin about!! ive some full-roller components before & thought that the 3x00's were full roller, also my apologies i coulda sworn the roller ends ive seen were on the ends of the pushrods but now seeing the lifters i remember that they are not. great info about the 3x00 equipment & you answered my question very well as always.
                i thank you my good sir
