Swapping DOHC for 3X00
  • IsaacHayes
    Mr. Orange.
    • Apr 2006
    • 6030
    #106
    The oil filter adapter will not replace with a gen3 one, because the gen3 one is 1 bolt vs the gen3.5 3 bolt one. I'm not sure if you can screw the oil filter on the block without the adapter like you could the gen3s. The OPSU from the TDC should work just fine.
    The log manifolds can work but still flow horribly. Someone told me that the 04+ impala 3400 logs have the ports opened to the size of the 3500 manifolds, but then choke down on the inside of course... The TDC 3.4 KS will work fine for the 3500 too.
    • jmgtp
      • 1219
      #107
      Can't I just use the 3500 oil filter adapter as is? I don't need the oil cooler. Sure its kinda nice but not at all necessary. The only thing I can see being a problem is if it gets in the way of my a/c lines.
      The a/c bracket is one of the last obstacles I have. The only other big piece of hardware I need is a drivers side torque strut bracket (engine side) and dogbone. I'm not sure how the bracket bolts to the engine though and whether or not the LX9 has provisions for it. I imagine it does since it was available in W body Impalas.
      Sidenote... the motor came with a AC Delco P47 on it. I was glad to see a decent filter on there and not something like a Fram. Makes me think it was well maintained!
      I have the car parked, well wedged would be a better word, in a 2 car garage against the back wall... making this a REALLY tight 3 car garage. It took a solid hour to manuever it back there due to a cement pillar and wood staircase. It was either parked like this or stay our undriven all winter. So, swap is definetly postponed until spring. Thats ok, gives me time to really prep the motor and collect everything I think I'll need.
      1994 Corvette
      LT1/ZF6
      2006 Dodge Dakota 4x4
      3.7/42RLE
        those HORRIBLE people! don't they know the PF52 is better?
          • 9185
          #109
          It depends... On my Beretta, with the oil cooler sandwich adapter, the PF52 sat down too low and was unprotected against road debris. So in that case, the PF47 is better!
          • gpse3400
            • 1460
            #110
            I can't believe you know this stuff off the top of your head!
            I used to live, breath, and eat W-bodies and 60 Degree V6s....Like Driving standard, once you learn you never forget. But I had alot of good people helping me to solve problems. Not for nothing, I was the only one pissed off enough to do this swap years ago. I really gotta get back in the game...
            Like I said there is a fitting on the GEN 3 to screw the filter direct onto the block, You can fasten it with an allen key. Infact maybe a minivan 3500 will have that part readialy available. Run a PF 52 if you can otherwise a PF 47 will suffice.
            The TDC oil cooler has the wrong dimensions and wont mount up corrently. Mainly due to the A/C being in the way. With the pushrod engines, an oil cooler is not nessesary but if you can find it run with it.
            The torque strut bracket you need is from a '96 + engine, and the A/C bolts through that...So you really need the A/C to make this all work well.... Like I said maybe you can just away with just chopping the bottom half of the bracket and using 10.9 bolts to secure the bracket to the block with only 2 bolts.
            Lorenzo
            • IsaacHayes
              Mr. Orange.
              • Apr 2006
              • 6030
              #111
              Brad, strange, with the angled adapter a PF52 is protected just fine on my car... It sits above the subframe...
              Lorenzo, the 3500 will not accept the 3100/3400 style oil filter adapters... But maybe they have something like you mentioned for the van 3500s. I was not aware that another adapter is put on to put the filter right on the block. I plan to swap my 3100 adapter over to the 3400 engine on my stand which has the filter right on the block. Good to know.
                • 9185
                #112
                Here is a pic of the adapter, the oil cooler adapter and a PF52. Its hard to tell from the angle, but it sat just below the oil pan.
                • IsaacHayes
                  Mr. Orange.
                  • Apr 2006
                  • 6030
                  #113
                  Ah I missed that you had an oil cooler on there. Never seen one before. Yeah I could see that would be too low with the oil cooler on there. With just the standard adapter it's about right, anymore and yeah that would be too low.
                  • gpse3400
                    • 1460
                    #114
                    I would not consider any downward adaptor for the w body, just no room in that direction...The regular GEN3s have a fitting screwed into the block. I am thinking that if you swap the cooler/adaptor with this fitting, then you can run just the oil filter. I would definatley use a minivan spec 3500 as a model since thier frames and exhaust routing is similar.
                    Lorenzo
                    • jmgtp
                      • 1219
                      #115
                      Hmm... I thought the downward facing oil filter adapter would be OK in a W car. I'm trying to visualize it now and the more I think of it the downward adapter would put the oil filter into the subframe but I'm just not sure. I'll have to check PCGuys thread again to see what he did there.
                      If I use only 2 bolts on the a/c bracket even if they are a high grade I'm still a little worried about using the dogbone mount on the passenger side. If I use the DOHC rear mount, the pushrod lower mount and a single dogbone on the drivers side is it going to be too sloppy?
                      1994 Corvette
                      LT1/ZF6
                      3.7/42RLE
                      • jmgtp
                        • 1219
                        #116
                        This may be a question for CNCGuy but I read somewhere on the forum that a 3400 crank pulley is necessary to work with the TCE external crank trigger? Is it true that my LX9 factory crank pulley/dampner will need to be swapped with one from a 3400? Also read that the 3400 pulley is a bit smaller hence underdriving the accessories in comparison to the LX9 pulley. If I do need the 3400 pulley will ANY 3400 or 3100 pulley work or only certain years/makes/models?
                        Also I used the 'search this thread' feature in PCGuys thread and found that I will need to mount the oil filter to the block. I'm not sure of the specifics on it yet as I have never removed an oil filter adapter. I also tried searching for crank pulley but didn't come up with any relavent hits to what I am asking above.
                        1994 Corvette
                        LT1/ZF6
                        3.7/42RLE
                        • IsaacHayes
                          Mr. Orange.
                          • Apr 2006
                          • 6030
                          #117
                          The LX9 dampener is very large. Get one from a 3.1/2.8/3100/3400 gen2/gen3 and swap it on. You don't need the 24x tone ring or sensor because you are not OBDII so even the gen2's will work. Not sure why they went to a larger one overdriving the accessories on the LX9...
                          • gpse3400
                            • 1460
                            #118
                            If you use the TDC rear lower mount I can gurentee that there will be absoultely no slop. Hell you can even run it without any torque struts its so stiff. But....I wouldnt advise it.In fact you may have to push the engine a little to get the torque strut brakets on the tie bars because the engine will sit so vertical.
                            Lorenzo
                            • Grand am gt switzerland
                              • Oct 2009
                              • 9
                              #119
                              I sell it for not use, 1 Street Cam new $ 180 , 1 Set of Custom length Hardened pushrods are the correct length for our performance cams new $90 . I have These Items, bought from ( Wide Open Throttle Technologies LLC), 1Set Hyd. Lifter SEALED POWER Part # HT2270 new $ 120, a Underdrive Crank Pulley 2.8/3.1/3100/3400 V6 GM complete with damper and new serpentine belt length ! + ARP Crank bolt !! $ 140. These Items should be used for a3100/3400 V6 GM 60° Engine (M) !!!!! For more information, I am pleased to respond to this e-mail ( francesco-r@hispeed.ch ) Best Regards from Switzerland
                              • 95Grand-Am
                                • 268
                                #120
                                (a Underdrive Crank Pulley 2.8/3.1/3100/3400 V6 GM complete with damper) Where did you find this, and how much was it?
