2.8 to 3400
  • chris3100
    • Oct 2009
    • 14
    2.8 to 3400
    hello iam new here so please bear with me ,i have 86 cav with 2.8 low miles. would like to go 3.4,and know 93-95 f body motor would be easiest but are nowhere to be found . if i use a 3400 short block and bolt my iron heads,intake,dist.etc.what kind of compression should be expected? not looking for hp. i want it to look stock just more torque.i know putting 3400 aluminum heads on in place of irons on a 3.4 f motor will give 11.0 roughly. so other way would be ridicuosly low ???? cant seem to find the answer. help!
    A 3400 would probably bolt in easier then an F-body 3.4. FWD engine to FWD engine.
    • chris3100
      • Oct 2009
      • 14
      2.8 to 3400
      That is what I plan on using , a 3400 short block with my 2.8 heads ,intake ,timing cover ,dist so that it will look stock when u open the hood.I just need to know if I will have a usable compression ratio with the iron heads on the 3400.
        nope, it'll be like 7:1.
        your best bet is to put in the whole 3400. Most 5 speed Jbodies with stock 3400's are putting down about 190 HP and about 210 TQ to the wheels, that's about 100 more HP and alot more torque than a 2.8.
        your other option (although ugly) would be to put 3.4 camaro pistons in the 3400 block, with your iron heads it would be about 9.5:1. You'll pick up a little bit of torque and maybe 20 HP. pretty big waste of time in my opinion
        • chris3100
          • Oct 2009
          • 14
          thank you for the info, I kind of thought the compression would be too low.I was able to get a short block for less than $100. probably will do a whole 3400 swap in the future . at present i am an unemployment statistic. Thanks again
            If you haven't already, check out www.v6z24.com . More info then you'll ever need about the Jbody and engine swaps.
              You aren't the only one, sadly. Got the axe 2nd week in January '08, found a job in the middle of summer, worked there for 2 months and they shut the doors. Really haven't found anything since :/ Best of luck to you in your job searching.
