03 to 02 3400
  • McNastie
    • Dec 2011
    • 3
    03 to 02 3400
    I have to put a motor in a 03 grand am gt the only thing i can find locally is out of a 02 Alero. The interchange said 03-05, realizing most of it will be the same what are the differences going to be? thank you.
  • slowalero
    • Nov 2010
    • 48
    There weren't that many differences in the LA1 3400 found in N-body's (Grand Am, Alero), especially between those years. It is however technically illegal to swap an older engine in a car. This is purely political, and it refers to the fact that each year emissions standards are updated. As far as I know, emission standards didn't change those years. If they did, GM got away with tuning the PCM.
    The biggest difference in 3400's came in 2000 when the injectors changed, the upper intake manifold changed for the new EGR valve, and camshaft position sensor changed. Obviously, your car is newer than 2000 so these changes don't apply to you.
    There are some other, smaller differences but they too are impertinent details.
    2001 Oldsmobile Alero GLS Coupe 3.4L 134k Redfire Metallic-blown up and dented. Major rehab in store-H.O. V6 swap, fresh body and other goodies...
    1999 Oldsmobile Alero GLS 3.4L 184k Gold Metallic-bone stock, soon to be daily driver, 16's and leather
    2001 Oldsmobile Alero GL 3.5L 78k Redfire Metallic-stock swap, TCE 65mm TB, Delphi 28# injectors, more later
    1999 Oldsmobile Alero GL 3.4L 203K Black-bone stock, drilled/slotted front rotors, killed 4 deer and a Geo--RIP 5.23.12
    • bob442
      Show Me Your KITS!
      • Nov 2008
      • 1305
      the spark plugs might* be different lol
      • McNastie
        • Dec 2011
        • 3
        Swapped the motor out and runs great now its not shifting right. it will accelerate but you have to lift off the pedal slightly for it to shift and it wont go into passing gear, the car downshifts but then just revs up to about 3500 and doesnt accelerate. Thinking the valve body is sticking, or maybe I should try the spark plugs. lol
        • bob442
          Show Me Your KITS!
          • Nov 2008
          • 1305
          check your MAF and TPS sensor and check back, MAF will effect APC pressure and TPS will effect shift patterns
          • McNastie
            • Dec 2011
            • 3
            will do, I thought about the TPS but not MAF. I will do that. thanks.
