3400 swap questions
  • nateleduc
    • Jan 2012
    • 2
    3400 swap questions
    I've been looking into the 3x00 swap. Recently I ran into engine issues and had to replace a head gasket. I planned on doing the swap around spring break, but since I have the block naked I though about jumping into it. I wanted an opinion on a few things before I start it though.
    I've got most of the parts for the swap, heres what I have and what I believe I need
    Have:
    3400 heads
    3400 upper and lower intake
    fuel rail/injectors
    coolant neck
    need:
    headers
    pistons
    two sensors
    ECU
    push rods from 3.1 91 cavalier
    I literally pulled the entire upper from an 3400 Impala so I do have all the small things. Now is it true you can use the ECU from a 3.1 Cutless and the tuning is dead on? I'd probably postpone it till Spring break if I had to use Mega squirt.
    Pushrods- I also read that the 3.1 cavalier's pushrods will work in the swap. Most people have said I'd need custom pushrods, and that's it, no measurements or anything.
    My last question is, is there absolutely anything I can do to avoid changing pistons? I'd really like to avoid sending it to a machinist shop if possible. If I have him change out my pistons I'd probably have my bearings checked/replaced. I have no plans on boost for this motor
    My motor has 130K miles on it, all but one piston are at 210, other is at 180/190 so I don't thing I'm in dire need of new rings. I don't mind swapping them but I really need to figure out what I'm doing soon as this car is my daily driver and is in 15 pieces, so if I need to have the pistons swapped I need to hurry and send it to my machinist
    Thanks for the input
    ~Nathan
    95 3.4 Camaro t5 Tranny
  • nateleduc
    • Jan 2012
    • 2
    got that answer. I'll order custom pushrods in the future, just want to get it up and running
    also I figure It's not to much of a hassle to change out the internals.
    Anybody know anything about the tuning for this? I've started reading into tunning on ftv6
