99 Alero 3400sfi swap into 96 Beretta 3100sfi?
  • driverof43
    • Mar 2009
    • 4
    I have a 96 Beretta with a bad 3100 in it. I have a 99 3400sfi from an Alero to put in it. What do I need to change on the 3400 for it to work in the beretta? I know the front Motor mount needs swapped. Will the timing cover/water pump from the 3100 work on the 3400?
  • MY91GT(Z)
    • Sep 2006
    • 387
    its a direct swap you just have to use all your sensors off your 3100 and get it tuned which you can talk to 3x00 modified on here or maybe on wot-tech site i believe may have a base tune
