I'm trying to figure how extensive I want to go with my above referenced build. Can someone give me either crank or rwhp estimates for the build with stock heads, intake, mild cam and one with p/p heads, intake, and big cam? Will be used as occasional weekend driver with an automatic.
3.4l/3500 horsepower posibilities
Im planning the same build (close) but turbo I've seen similar hybrids but without more specifics aka cam, level of porting ect id say from 235- 290 chp depending on alot im shooting for 300 on low boost so I can turn it up as I fine tune it
Sent from my SAMSUNG-SGH-I437P using Tapatalk
Originally posted by rcf4 View PostI'm trying to figure how extensive I want to go with my above referenced build. Can someone give me either crank or rwhp estimates for the build with stock heads, intake, mild cam and one with p/p heads, intake, and big cam? Will be used as occasional weekend driver with an automatic.
prob around 230 crank with just the cam.
full build up and you can get to 290 crank or so.
with your auto you can't go too big on the cam, or you will have to also get a higher stall converter.
