RWD hybrid owners enter please...
  • Maverick H1L
    • Jan 2010
    • 230
    What are you guys running a RWD hybrid using for plug wires? I had bought a set of 8.5mm 3100 plug wires and I have been having length issues, mostly with the 2,4,6 side being too long and the #1 being too short. I made a mistake when reinstalling my upper plenum and pinched my #1 plug wire under the plenum by the rear #6 port, and now I need another set of wires. So I am wondering what others are running...
    I'd like the #1 plug wire to be about 2" longer and the even cylinder wires to be several inches shorter (it's a straight drop to the plugs from the ignition module so why are the wires an average of 6" too long?) I'll be sticking with red 8.5mm wires...
    Or even some sort of kit?
    • 9187
    Magnecor.
    Brad
    via Moto X
    • Maverick H1L
      • Jan 2010
      • 230
      Well, I found a V8 kit on eBay. Only the plug ends are attached to the wires, so I should be able to cut them to length. With any luck, I should have wire left over in case one goes bad (and I'll keep the remnants of the set I have just in case).
      If necessary, is it possible to just buy terminals?
      • Guest
        When I had my RWD hybrid installed in my Jimmy, I mounted the coil pack on the firewall, near where the dizzy would have been and was able to use the plug wires that I had on the dizzy attached engine. I then went to a set of cut to fit MSDs.
        • Maverick H1L
          • Jan 2010
          • 230
          My AFPR is already behind the engine... I was originally going to mount the module assembly back there but I ended up changing my fuel system plans...
            I had my coils mounted on the firweall, then used a cut to fit Accel V8 set with straight boots. Worked great.
