3.4L/3400 Top End Swap
  • Robindehood
    • Sep 2013
    • 23
    You'll also need valve springs. Get the comp 26986 springs.
    I think I'm just going to get the cam package. It comes with those springs as well as a timing chain cover gasket haha. I'll also need the custom length pushrods and I'll probably also order a couple other things while I'm there that I need. Maybe I can get a deal for a decent sized order haha
    • peyo32
      • Feb 2014
      • 1
      Just swapped 3.1 chevy malibu engine to 3.4 engine? So far no problems. Any tips or anybody do it before?
      Sent from my iPhone using Tapatalk
      Using Tapatalk
      • Robindehood
        • Sep 2013
        • 23
        Not sure if you have the right thread man. This is for the top end swap, not an entire engine swap.
        • Robindehood
          • Sep 2013
          • 23
          Well I guess I could give you guys an update. I ordered a custom cam from wot-tech along with the hardened custom length pushrods a couple of months ago and I'm just waiting on my lifters and springs. I was just wondering what you guys think I should run for injectors?
          • caffeine
            • Jan 2012
            • 1489
            28# trailblazer injectors
            '86 Fiero, 3500, 4-speed
            • Robindehood
              • Sep 2013
              • 23
              #21
              Damn caffeine, you're quick haha.
              • Robindehood
                • Sep 2013
                • 23
                #22
                What years are they in?
                • Robindehood
                  • Sep 2013
                  • 23
                  #23
                  Also, would it run ok on the stock 3400 injectors?
                  • caffeine
                    • Jan 2012
                    • 1489
                    #24
                    Probably depends on the cam whether or not stock injectors will be enough. AFAIK all trailblazers with the inline-6 have the 28# injectors.
                    • Robindehood
                      • Sep 2013
                      • 23
                      #25
                      Well the cam is wot-techs street/strip cam ground onto a flat tappet cam, specs are
                      259/265 adv duration
                      .506"/.506" lift
                      113 LSA
                      • Robindehood
                        • Sep 2013
                        • 23
                        #26
                        Can anyone chime in on lifters? I know flat tappet, but does it matter if they're high energy or magnum or anything? I'm planning on comp to match the cam
                        • caffeine
                          • Jan 2012
                          • 1489
                          #27
                          I wouldn't recommend stock injectors with that cam. Lifters I'm not really sure.
                          • Robindehood
                            • Sep 2013
                            • 23
                            #28
                            Hey man, is there any where else I can get ahold of you a little better if I have questions? Digits or Facebook?
                            • Robindehood
                              • Sep 2013
                              • 23
                              #29
                              Also back to the injectors. I can't seem to find any scrap yards around me that have any 4.2Ls that I could rob the injectors from. Does anyone know of any others that might work other than the #28? I remember reading somewhere that some from a 2002+ ecotech 2.2L fit right in the rail and I believe they were 24lb delphi multec II. Can anyone confirm if these would work?
                              • bachert24
                                • Jul 2014
                                • 73
                                #30
                                Why not get the injectors off a supercharged GP? They are supposedly 36#, but I flow tested mine at 29#. Works for what you wanna do.
