Ignition Coil Wiring
  • Dreamka
    • Sep 2014
    • 21
    I feel like this is a really dumb question but I don't have any spare time lately to get to the junkyard to check before they close.
    I am wiring up an LX9 in my 1999 Cavalier and am using a 1998 Monte Carlo 3.1 harness. I can't seem to figure out where on earth the plug is for the 3 pin connector on the ignition coil module next to the 6 pin connector.
    Did I miss pulling a piece of this harness from the junkyard? Does this 3 pin go from the ignition coil straight to the crank sensor as a jumper? I'm thoroughly confused. Any help would be great!
    Yes that is the crank sensor input... It's a 2 pin wire at the crank and 3 pin connector at the icm but still only 2 wires.
    • caffeine
      • Jan 2012
      • 1489
      Yes it is effectively a separate harness.
      '86 Fiero, 3500, 4-speed
      • Dreamka
        • Sep 2014
        • 21
        Perfect! Got it thank you!
