comp roller rockers
  • Rootie524
    • Feb 2010
    • 543
    comp roller rockers
    So i saw these on WOT today..im assuming they'd work in my 3.1 N body..
    but basically whats the advantage..would i see any real gains from it if i also have stiffer valve springs, custom pushrods, new liftersprings, and a comp cam?
  • asylummotorsports
    Banned
    • Oct 2005
    • 649
    You would have to consider the camshaft specs and go from there.
    Take the "total" lift devide it by 1.5 then multiply it by 1.6 and see what that gets you.
    You will also get a little bit more duration just for the extra time it takes the valve to open and close the extra, but it won't be too significant.
      • 9190
      That is actually a downgrade from what you currently have. Your existing rockers are roller fulcrum and 1.6 ratio. The ones you linked to are only roller tip and a 1.52 ratio. Keep what you have.
      • asylummotorsports
        Banned
        • Oct 2005
        • 649
        OOPS! My Bad for not reading well!
        3.1 threw me off
