rebuilding tce adjustable regulator
  • eckoxl
    • Jul 2009
    • 230
    is there anyway to rebuild it? mine is shot. stays at 20psi unless the screw is screwed pretty much all the way down.
    1999 Grand Am SC/T - 301HP, 365TQ - ARP Rod Bolts, ARP Oil Pan Bolts, ARP Head Studs, Mild Cam, 3500 Heads w/28696 Springs, Ported 3500 LIM & 3400 UIM, GT32R @ 12PSI, Rebuilt Trans, 42.5 Injectors, Racetronix Fuel Pump, TCE Adjustable FPR, SC/T Kit, SC/T Spoiler, Shaved Trunk, WOT-Tech Coil Overs, Solid Rear Laterals w/Poly Bushings, Control Arms w/Poly Bushings, Poly Engine & Trans Mounts, Front & Rear Strut Braces
  • G.I.Ceo
    • Sep 2010
    • 85
    I rebuilt my Casper adjustable one by buying a stock fuel pressure regulator and cutting off the top of it. I removed the adjustable top off the bad one by removing the three screws that hold it on. I then drilled the new one for the screws and put the adjustable top on the new one and it worked perfectly. All those TCE AFPR is a machined top on a stock fuel pressure regulator. You should be able to take it apart pretty easily.
    Sent from my Galaxy Nexus using Tapatalk 2
    "Living is doing everything you want to do and dying is everything else"
    • eckoxl
      • Jul 2009
      • 230
      i fixed it. i took it apart and found out the pressure plate is a penny. the pressure screw poked a hole through the penny so i replaced it with a quarted instead. problem solved
      • G.I.Ceo
        • Sep 2010
        • 85
        Wow its a penny? I can't believe they didn't just machine a plate. That is a good idea though about the quarter. I can't remember how mine was so I might have to pull it apart and look while it's off the car.
        • boomofdoom88
          • Oct 2010
          • 111
          A penny to a quarter? Thats a 2500% Increase in costs! lol
            i think i would have gone with a nickel.
            • Starglow
              • Jun 2011
              • 83
              Now that there is funny....
