3.4 DOHC Dress-up
  • series8217
    • Dec 2004
    • 387
    3.4 DOHC Dress-up
    I did some dress-up on my Fiero's 3.4 DOHC while it was out for a clutch change.
    This pic is the most color-accurate:
    The intake is cherry red and the cam carrier covers are a slightly darker maroon/cherry red.
    Note these pics were taken before I hooked a breather up to the two aluminum tubes, and I also hadn't installed the throttle cable bracket. It's all together now but I haven't had a chance to take any more well-lit pics. I hope these will suffice.
    Also my Getrag input shaft bearing took a dump so the motor is coming right back out again this weekend (I just put it back in last weekend for Fiero Westfest). Oui.
    -Steven
  • HayesPerformance
    • 783
    What Color of Red is that? It looks Metallic. I had been looking for a color like that for my DOHC. Thanks
    1991 Grand Prix STE
    3.4 DOHC
    1 of 792 Produced
    Extensive Mods Done
    1991 Lumina Z34
    3.4 DOHC
    Getrag 284 5spd
    1 of 30
    • series8217
      • Dec 2004
      • 387
      The intake is "Toreador Red", and the cam carrier covers are "Garnet Red". These are Duplicolor touch up spray can paints.
      • Sourmug
        • Aug 2005
        • 52
        That's absolutely gorgeous! Well done. I hope mine turns out as well.
        Nolan
        • gpchris
          • Feb 2007
          • 477
          Wow that looks great! I'm assuming that oil fill cap location is custom?
          • OldSkoolGP
            That guy over there
            • 930
            Would have to be. Looks pretty good. I'mm wondering where he got the delte pulley for the power steering pump.
            • Sourmug
              • Aug 2005
              • 52
              Do you have pictures or a link showing how you built your intake?
              Thanks
              Nolan
              • series8217
                • Dec 2004
                • 387
                Thanks. Yes, that is a rear cover on the front, and a rear cover on the back with a fill cap boss from Jegs added in. I could have just stuck the rectangular cover on the front so I had an accessible oil fill, but I think these ones look much cooler.
                No, it was just a short weekend project... cut the plenum off a little bit past the intake bolt bosses, leaving the throttle body.. weld on a 3" aluminum tube.. add vacuum fittings..
                It's from some 3800 SC car. I bought the pulley at Kragen or Autozone.. I forget the application. I made a pulley spacer and ran a bolt through the top power steering pump hole, with a nut on the other side. I also added a brace from the top bolt hole to the bottom bolt hole so it doesnt stress the weak casting.
                • Sourmug
                  • Aug 2005
                  • 52
                  Would you mind taking a picture strait down on top and one of the vacuum fittings that you added if possible?
                  Thanks
                  Nolan
                  • series8217
                    • Dec 2004
                    • 387
                    The fittings are under the intake. I just drilled and tapped the plenum for NPT of the appropriate size for barb fittings...
                    Here's the straight down pic I took
                    What are you trying to see?
                    • Sourmug
                      • Aug 2005
                      • 52
                      On nothing in particular... I'm just trying to see how you cut the plenum and constructed it so that I can shamelessly plagiarize your work.
                      Thanks for the picture.
                      Nolan
                      • series8217
                        • Dec 2004
                        • 387
                        Good luck..
                        • Sourmug
                          • Aug 2005
                          • 52
                          Thanks!
                          I hope that you don't mind if I copy (as far as I can) what you have done.
                          Did you do the welding yourself?
                          Nolan
                          • series8217
                            • Dec 2004
                            • 387
                            Feel free.
                            No, the welding was the one part I didn't do myself.
                            • HayesPerformance
                              • 783
                              Are those ARP fasteners for the intake?
                              1991 Grand Prix STE
                              3.4 DOHC
                              1 of 792 Produced
                              Extensive Mods Done
                              1991 Lumina Z34
                              3.4 DOHC
                              Getrag 284 5spd
                              1 of 30
