Aftermarket ECU
  • sandbum01
    • Sep 2007
    • 4
    Aftermarket ECU
    Has anyone ever installed an aftermarket ECU on their 3.4 like a LINK or a HALTECH. Does any one know if there is a crank position sensor and cam position sensor and what the timing on them are. I'm trying to put this engine in a dune buggy but i'm having trouble with a Link ECU I have and they want to know the crank timing and if it has a cam sensor and it's timing. Do any other motors use the same timing? Any thing will help
  • timg
    • Feb 2004
    • 718
    If I remember correctly, the MegaSquirt guys have a great writeup on our vehicles. The following is assuming that I remember things correctly. There are two crank position sensors. One is a 24x and the other is a 7x (6 for each cylinder plus one reference). There is also a cam position sensor on some of the 3.4's (depends on model year) IIRC, it's a single tooth. The sensors are a mix of hall and magnetic.
    Tim
    325 whp 350 lb-ft
    • timg
      • Feb 2004
      • 718
      EFI, Fuel Injection, Auto, automotive, car, TPI, computation, ECU, MegaSquirt, GPIO, MicroSquirt, Sequencer, stim, MegaShift, MShift, DIY, transmission, 4L60E, 4L80E, controller, shifter
      Tim
      325 whp 350 lb-ft
