Air pump option?
  • pwmin
    • Aug 2004
    • 394
    pipe plugs worke fine on mine... (after i put the right size in, lol.)
    91 GTP HM-284 GONE :(
    98 Spawn of Satan (L67 Regal)
    87 V10 SM-465/Mild 350
    06 Cobalt SS/SC GONE :(
    • Dave96z34
      • Apr 2005
      • 624
      For future reference to any one plugging the egr hole the thread is gas compression with a Inverted Flare. Any hydraulic shop store should have it. Will look like this but a larger size. https://www.fastenal.com/web/product.../440271-131280
        • 9190
        Thanks for the update, but wow... Just over 7yr resurrection!
        • Dave96z34
          • Apr 2005
          • 624
          Lol 3 years ago I swapped in engine number 3. I went to block it off again and found I had used the wrong plug from the beginning. I found the thread was the same as compression gas. But the flare was inverted. So the plug I found it was not inverted. I stuck it in a lathe and changed it. I think the only place you you would see it is in a hydraulic shop. Engine number 4 is in its crate in the garage.
