95 GTP Sputtering
  • bve32k
    3.4 DOHC FTW
    • Jun 2005
    • 475
    95 GTP Sputtering
    Ok. I am going to try to explain this the best as I can.
    My car under a load will sputter. When I hit the gas it will start jumping around. Usually only around speeds higher than 30. It does do it though sometimes in the lower speeds.
    But I put some higher unleaded octane into see if it would help it any and it did seem to go away a little bit. Wasn't there as much but once I had to fill back up it started again.
    Yesterday it was backfiring while I was driving. The backfire is not frequent. Only happens randomly. I tried to re-create the seen on video, but it would not do it anymore. It did not backfire at all today.
    This sputtering is very noticeable in OD/TCC lock up. I tested the coil resistance and they came out to 6.47, 6.40 and 6.33.
  • grandprixgtp_91
    • Nov 2003
    • 758
    did you check the wires? bad wires can cause that, even more in damp weather or cold mornings.
    Jake
    • bve32k
      3.4 DOHC FTW
      • Jun 2005
      • 475
      Wires are brand new. Only have about 2500 miles on them. 8.5mm Magnecor wires.
      I am changing plugs tomorrow. I will see if that fixes it. The plugs only have 2500 miles on them too.
      • z34phoenix
        • Jun 2005
        • 469
        what gap? .045 is what they should be
        as always check vac lines
        • bve32k
          3.4 DOHC FTW
          • Jun 2005
          • 475
          I changed the plugs and it seemed to have fixed the problem.
          Here is a pic of the plugs that came out of it. They are in order. Top left plug is piston #1 and bottom right one is piston #6. These plugs were pre-gapped from factory @ .060 and thats the way I left them.
