what has to come off to seperate the motor from the tranny. i have already taken off most of the crap for a head gasket swap that went wrong. i have taken the bottom bolts out of the engine mount but did not mess with the tranny mount.
i have taken off all the bellhousing bolts. but the motor is not seperating from the tranny.
do i have to remove the tq converter bolts?
if so how? i have taken off the little starter cover and i see one of them. i can use a ratchet wrench, but i don't know how long the bolts are. there is not alot of space between the flex plate and the oil pan.
my next step would be to remove the starter to get to the converter bolts?
is there anything else i need to take off?
