RPM Signal wire
  • grandprix34
    • 168
    RPM Signal wire
    From the input harness on the ECM, which wire is the RPM signal wire? I have a manual describing all the wiring into the ECM but can;t seem to find the wire that inputs RPM....
    Can anyone please help me with this? Would it be safe to use the RPM signal wire coming out of the instrument cluster?
    \"Pree\" - 93 Grand Prix SE - 3.4L Twin Dual Cam
    - FFP UD Pulley - FFP Chip - 8mm Taylor Wires
    - 160* T/stat - Dual 40 Series Flowmasters
    - Hi-Flo Cat
    15.2@95mph - GTECH P/B
    http://home.rgv.rr.com/tjperformance/Cap0005.mpg
  • jmgtp
    • 1219
    Pin D19 = reference signal
    the other end of the wire for D19 on the ecm is connected to the large connector on the ignition control module, Pin E on the ICM.
    My GM service manual has the schematic: Book 1, pg 6E3-1-16 (schematic is for 3.1 engine but dohc is the same).
    ECM]--D19<--------------------------->E--big connector--[ICM
    1994 Corvette
    LT1/ZF6
    2006 Dodge Dakota 4x4
    3.7/42RLE
