i believe it is charcoal, i'll take a few more pics. i bought the car with the 5 spd swap and battery relocation already done.
just lmk when you get those parts. thx.
Found a black 92 GTP at the local pick n pull
I have paypal yes.
That makes more sense I have a spare seat belt piece (just recovered the doorpanels - and quarters as well) I also have the lower plastic cover that actually coverd the belt assembly that's what I though you meant. I'll have to wait for it to warm up here and then go back to get the belts and carpet. Your car interior is dark grey/charcoal right??
Off topic - did you do the 284 swap yourself or buy your gp with it already done?? I saw some posts you made about the swap a while ago...Last edited by GTP091; 12-15-2008, 11:44 PM.
lower seatbelt covers?
on the front seatbelts, i'll take em. i have the pieces they plug into so i just need only the front belts.
yes definately on the carpet
lastly, did you get one of those little plastic pieces the seatbelts go through? not the little flip latch, i have those. all i need is one, same on the coat rack hanger but since you have 2 i'll take em. it is a little plastic piece located on the rear top of each door panel and they are screwed into the door itself by 2 long phillips screws.
i have a 94 coupe btw.
if you get bored you can check it out here: http://www.dohcfiend.60degreev6.com/
looks like you have done a few mods yourself.
can you pm me a total? do you take paypal?
thanx a bunch for getting me 99% there. if i do not find a leather driver's seat, i may invest in economical lightweight racing seats.
There were two more GP' there when I went so was able to pull the best stuff. I got 2 of the coat rack hangers, two rear ashtrays, and both of the lower seat belt covers all in perfect condition. The charcoal seatbelts on all three cars are sun faded on the strip where they pass in front of the window. I would pull the best of all three but still not sure if you want them; they are lighter grey in this spot about 2 feet. They want 15 for each belt plus the latch ( I assume you need the latch as well??) Other wise in good shape just need a good scrubbing in hot dishsoap. It was actually snowing when I went there so I didn't bother with the carpet but should be able to get it. Carpet looks like it is in good shape the other car has a few dark stains so I wouldn't touch that one. What year is your car??? Coupe right??Originally posted by dohcfiend View Postshipping shouldn't be bad since none of it is heavy. the carpet may cost a little more though if it is usable. lmk something. thx.Last edited by GTP091; 12-13-2008, 05:28 AM.
To get the seat belt off at the door mount you pull the circular cover and there is a 15mm shallow nut underneath. I wrapped a 2X4 with padding and used it to brace against the window frame to stop it from spinning; worked like a charm. The rest of it unbolts when the door panel is off. I can check them out the next time I go there; maybe thursday.Originally posted by dohcfiend View Posthere is a pic of the leather seat, the flash is a little bright so it is actually a little darker but you'll get the idea.
how do you get the seat belt off at the top?
as long as the seatbelts are not trashed, i'll take them since my current ones are tan.
and if you happen to come across a driver's side leather seat to match that one lmk but it isn't a big deal b/c if i cannot find one i'll eventually buy aftermarket ones.
lastly lmk on the carpet, i can lay it out on the concrete and run a carpet cleaner over it 20 times unless it is horrid. if it is savable. roll it up, wrap it in plastic and i'll pay for your materials.
thx
I live in BC not to sure how shipping would go. I could put this all on ebay for what I get charged for it, probably work the best, take pictures of it all....
thxLast edited by dohcfiend; 12-08-2008, 06:52 PM.
No worries on the labor it only takes a minute to pull this stuff
I already pulled the seat belt covers thinking mine were scratched they weren't and either were these.
I can get the ashtrays out for sure another GP showed up so two out four should be good.
The carpet is heavily soiled so I don't think you would want it, but I'll look again
I didn't see what condition the seat belts are in, but I can look. My light gray belts were quite dirty but I restored them with oxy clean, the look new again. The belts are easy to take off but you have to pull the door panel.Last edited by GTP091; 12-15-2008, 11:45 PM.
i'll upload a pic or 2 over the weekend and if it matches the interior in them, can you pull a few interior parts for me? i'll re-imburse you for labor.
most are easy.
1. one of the little coat rack fingers in the back of the car
2. both of the little ashtrays for the back if you cen get them out without breaking the tabs
3. the passenger (or driver) side plastic thingy for the seatbelt. it is where the seatbelt meets the doorpanel, it is plastic, and is held in by 2 phillips screws
4. the carpet
5. both front seatbelts plus you have to tell me how to remove them b/c i do not know.Last edited by dohcfiend; 12-05-2008, 09:35 AM.
Went back today and pulled the HUD out for $9.99. The seats are charcoal grey; some dick pulled the rear seat and cut squares out of the flat parts in all the other seats to get the leather.
what color any ways? want to guess Brown...
I guess I'll just keep watching localy
