CAI or cold air intake???
  • hypedz34
    • Feb 2009
    • 78
    I was wondering what exactly is a CAI and hoe does it work???And wich is better a CAI or your average cold air intake with a cone at the end.Also how exactly would you go about installing a CAI??any help is appreciated??THANX
    CAI=Cold Air Intake...
    are you talking about a FWI: Fender Well Intake?
    so called CAIs from ebay are junk, most of the time they are WAI: Warm Air Intakes, meaning it usually worse or similar to the stock option.
      Most ebay CAI are just a filter on a short pipe in the hot engine bay. That's more like a hot air intake and will actually hurt overall power compared to most stock air boxes since you'll suck so much hot air in.
      A real CAI/FWI locates the filter outside of the engine bay where it gets cold air, and also has a cone which has more surface area than an air air box with a small snorkel. Maybe 4hp at the wheels on average depending on engine.
      • hypedz34
        • Feb 2009
        • 78
        ok thanks that helps me decide what exactly to go with intake wise.how would you install an FWI?
          In my car there is a 3" hole by the battery, run the intake pipe in there, and unbolt the splash shield in the wheel well to install the filter on to that, then put back the splash shield.
          • hypedz34
            • Feb 2009
            • 78
            ok i see what you are saying.nut wont the intake pipe be in the way of puttin the splash shield back?or do i modify it to fit around the intake pipe?
              In my car there is space behind the splash guard between the inner fender/body. Depends on the car.
              Pic without splash shield installed:
              No modifications there. There is empty room behind the splash shield.
              When I do mine I will use a different shaped filter, and mount it a little higher than you see in that pic, to keep it cleaner and out of water.
              • 1988GTU
                LB62LHObbqftmfw
                • Nov 2005
                • 2475
                A FWCAI is better than the plain jane CAI sitting next or infront of the battery.
                What do you want more of? Money in your pocket or more performance in your car.
                A wai is just for space and looks.
                • hypedz34
                  • Feb 2009
                  • 78
                  im going with the fwcai.in order to do this it would be like the normal cai tubing except having it stretch to outside the engine bay where the coller air is right?
                    that is the gist of it...
                      I cut a large portion from the bottom of my airbox out because I didn't like the size of the little snorkel that went behind the headlight. It really is cut out more then I should have done, as I'm sure I'm getting some of the warm air from the engine bay, but not near as much as a WAI. I've gotten comments on my "exhaust" when I've wound it out too, but it was funny telling them "My exhaust is stock style, just replaced with mandrel bent 2 1/4. That wasn't my exhaust you heard." I probably didn't gain anything, but I wouldn't ever put a stock air box in it's place and loose that sound.
                        you know, i did the same thing... about a 3 X 3 square on the bottom right above some type of a/c equipment, and yes it does change the motor's noise quite a bit...
                          I hacked off about half of mine. I went from mounting point to mounting point, then strait up the sides and just under the sealing flange for the filter element, and that whole front piece came off which is why I said it probably still gets some of the heat from the compartment. I should snap a pic of it one day....
                          • Alxsmt
                            that one guy
                            • Feb 2007
                            • 725
                            since when are is a fender mounted CAI called fmcai? lol. if its outside of the engine bay its a cool air intake imo. who cares where it is as long its the most convient place for it
                            mine goes down in front of the radiator by the slave cylinder, under the battery and through a factory hole and around the inside of the bumper to infront of the radiator. kinda a pain but its the only place i could run it without cutting the body
                            • 1988GTU
                              LB62LHObbqftmfw
                              • Nov 2005
                              • 2475
                              It's called a FWCAI so most people don't get the misconception of the infamous WAI mounted above the x-over &/or next to the battery pointing at the nice hot radiator.
