Any way to put a temp guage on the motor
  • qwikgta
    • Feb 2004
    • 42
    As the subj says. I have a guage inside the car, but its not moving off 100'. So I want to put a guage on the motor.
    96 DOHC motor. Running a 91 "9396" ECM in an 88 Fiero.
    I may have messed up the wiring, if so, its the only wire I messed up, but I know the motor is getting hotter than 100', so I must have a prob. Not sure if a new sensor would fix it, I may try that next, but I guess im asking if a guage attached to the motor would be more accurate?
    Thanks in advance.
    Rob
    being a 96 motor, it should only have 1 temp sensor, with 3 wires coming out of it. 2 go to the ECU, while the third goes to the dash. sounds familiar?
      1 should go to the dash, 1 should go to the ECM and 1 should be a ground ref.
      • qwikgta
        • Feb 2004
        • 42
        Thanks for the reply.
        Actually, there are two sensors. One is a coolant temp guage sensor, the other is a coolant temp sensor. One is a two wire (black/tan) that goes to the ECM, the other is a single wire (green) that goes to the gauge via the C100 connector.
        That was not the question. But I got an answer when I went to advance auto and noticed that they had temp guages and I see that they screw into the motor at the stock sensor location.
        Thanks again.
        Rob
          wait.... you have 2 different sensors/senders? you're sure the motor is a 96? it should have it all in 1, unlike the 95-earlier motors that have the setup you described...
          • qwikgta
            • Feb 2004
            • 42
            Yes its an 96 motor, and yes I have the two sensor set up. I also have the GM Tech Manual and its all in there. Not sure about the setup your talking about, I don't know much about the other motors, just this one. Its all stock, so I know it has not been messed with. I pulled the motor myself and no one has modified it. I noticed that the 91 motor/ecm has the same setup because I am using a 91 ECM/Harness.
            Thanks again for the help
            Rob
            • Ghettoracer
              The GhettoBucket
              • Sep 2009
              • 96
              It all depends if he wants to go with a mechanical temp gauge or an electrical temp gauge. I would go with a mechanical temp gauge cause it gives you less the hassle than an electronic (ie wiring, tracing, etc). I would say if the gauge on your dash is stuck, take the coolant temp gauge sender out and replace it with a mechanical coolant sensor and it should take under an hour or so of wiring the lights of the gauge and replace the sender with a mechanical, run the sensor copper wire, and mounting it.
              sigpic1993 Pontiac Grand Prix SE, 3.4L DOHC 24 Valve V6 MFPI, 5 speed, completely stock, bucket on a budget!
