LIM gaskets
  • 94GPGTP
    95 Grand Prix GTP
    • Apr 2007
    • 593
    LIM gaskets
    I have 91-95 LIM gaskets laying around.. Do they fit the 96-97 by a chance? i dont want to buy extras if i dont have to and can use these..
    Robert
    New Rebuilt 3100
    New Rebuilt 4T60-E
    Exhaust
    Drilled/Slotted Rotors
    White
    3" Magnaflow Catback
    90 Pontiac Turbo Grand Prix
    5 Speed Swapped
    127,000
    Spec Stage 3 Clutch
    230,000 mile Getrag 282
    Emissions Deleted
    Brand new Engine 1,000 Miles
    Fully Custom Built car
    I've been told the 96/97 gaskets are thinner then the 91/95 gaskets (sounds like a much better design), so I would have to say no.
    • RedZMonte
      • Feb 2004
      • 1378
      from what i understand, no. i got the oem gaskets WAY cheaper then felpro.. felpro '96 gaskets are like $70-80. OEM are like $35
      Shane "RedZMonte"
      1992 Lumina Z34-VIRGIN (RIP)
      1992 L67 Lumina Z34 (SOLD)
      1990 Turbo Grand Prix (SOLD)
      • bve32k
        3.4 DOHC FTW
        • Jun 2005
        • 475
        95 gaskets will not fit the 96/97. Just go to the dealer to get the gaskets. They will be way cheaper than anywhere else.
        • 94GPGTP
          95 Grand Prix GTP
          • Apr 2007
          • 593
          hmm thats wierd.. i compared the 91-95 gasket to my spare 96 LIM and my 95 LIM and it all lined up but the thickness i have not checked.. but i am going to the dealer to get them if they r cheaper..
          Robert
          New Rebuilt 3100
          New Rebuilt 4T60-E
          Exhaust
          White
          5 Speed Swapped
          127,000
          Spec Stage 3 Clutch
          Emissions Deleted
          • bve32k
            3.4 DOHC FTW
            • Jun 2005
            • 475
            I am not sure about the LIM gaskets..I am almost positive they are cheaper at the dealer. I do have the part #'s for the UIM gasket and the throttle arm gasket that goes between the UIM and the throttle arm.
            • 94GPGTP
              95 Grand Prix GTP
              • Apr 2007
              • 593
              i already have all the UIM gaskets i got them from rockauto.com.. i knew i have to remove the UIM to do the T-belt so i bought 3 gaskets of each but didnt get a LIM set because wasnt sure if i should do them or not but now i think i am its only going to be an extra 20 mins of work.. expecially it being on a engine stand/ ground
              Robert
              New Rebuilt 3100
              New Rebuilt 4T60-E
              Exhaust
              White
              5 Speed Swapped
              127,000
              Spec Stage 3 Clutch
              Emissions Deleted
              • 94GPGTP
                95 Grand Prix GTP
                • Apr 2007
                • 593
                Ut Oh.. on gmpartsdirect and its showing the timing belt is only for 91-95 and 96-97.. is that true or all the belts the same?
                Robert
                New Rebuilt 3100
                New Rebuilt 4T60-E
                Exhaust
                White
                5 Speed Swapped
                127,000
                Spec Stage 3 Clutch
                Emissions Deleted
                • bve32k
                  3.4 DOHC FTW
                  • Jun 2005
                  • 475
                  Belts are different. 91 - 95 have one belt and 96 - 97 have a different belt.
                    The 96-97 belt has rounded teeth, the 91-95 has square. 96-97 belts should run cooler with that said.
                    • 94GPGTP
                      95 Grand Prix GTP
                      • Apr 2007
                      • 593
                      hmm ill have to check to see what that spare belt i have fits.. I know it was like to long when i tried it on my 94 gtp and my 95.. maybe its a 96 belt idk..
                      Robert
                      New Rebuilt 3100
                      New Rebuilt 4T60-E
                      Exhaust
                      White
                      5 Speed Swapped
                      127,000
                      Spec Stage 3 Clutch
                      Emissions Deleted
                      • 1988GTU
                        LB62LHObbqftmfw
                        • Nov 2005
                        • 2475
                        Cant the new belt be used IF you swap all cogs, the tensioner, and idler?
                        • 94GPGTP
                          95 Grand Prix GTP
                          • Apr 2007
                          • 593
                          I would just think swaping the cogs ans main drive pulley and it should work.. i have some investigating to do..
                          Robert
                          New Rebuilt 3100
                          New Rebuilt 4T60-E
                          Exhaust
                          White
                          5 Speed Swapped
                          127,000
                          Spec Stage 3 Clutch
                          Emissions Deleted
                            It should, yes. I was going to grab the cogs off of the engine in the yard I got my 96 style heads off of, but had no way to pull the intermediate shaft cog with the engine being in the car still I do believe the idler and tensioner pulleys are all the same, though.
