DOHC spark plug recomendations
  • Cidacious
    • Sep 2009
    • 85
    Before I read in the forums that Boschs were bad, I bought a set, and had GM install them w/ new wires. I currently have Bosch +4's in car with about 100 miles on them if that. They are much better than the AC's that were in the car, but I have read that platinums aren't good with this car. AC's make them, so should I avoid those too? Some have said to use Iridiums, and that AC makes them for this car, but their website does not list them for my 91 yet. I would like to get a good plug that will last a long time with no fouling or poor cold engine performance (boschs appear to possibly have this problem) I would rather not have to replace the cheapo AC's every 30K but I will if I have to if its the best for this engine.
    1992 Grand Prix SE 3.1l 155k SOLD
    1992 Grand Prix GTP 3.4l 55K
    1991 Grand Prix GTP 3.4l 5 speed 99K SOLD
    1988 Pontiac Fiero GT 2.8 5 speed Turbo 36K Sold
    2011 Mazda 3s 5dr 6 speed
    2008 Grand Prix GXP 5.3l 24K sold
    Just have the parts store look up Iridiums for a newer 660. Spark plug hole size/threads/depth is all the same on the 660 family.
    • W41duvernay
      • Oct 2009
      • 13
      I disagree. Think the best plug I came w/ the DOHC engines is the Torque master plug.
      If you can fab up some custom spark plug wires from MSD (w/ a low ohm rating), and wiring in A MSD DIS-2 spark box in there, then get the S-plugs from torquemaster. Watch youre throttle response go crazy.
      • RedZMonte
        • Feb 2004
        • 1378
        whatever you decide to go with i would stick to either NGK or AC Delco plugs... even the newer OE plugs from GM are NGK's. something to be said if GM is using them stock.
        S
        Shane "RedZMonte"
        1992 Lumina Z34-VIRGIN (RIP)
        1992 L67 Lumina Z34 (SOLD)
        1990 Turbo Grand Prix (SOLD)
        • W41duvernay
          • Oct 2009
          • 13
          Yo, red monte,
          I highly disagree. I've tried them all. Their was a new and improved GM plug (can't remember the name), Ive tried regapping the Splitfire plugs, NOTHING amps up that throttle response in a DOHC engine like that Torquemaster Splug. That's assuming the
          ignition can jump the extra plug gapp on those plugs. I Don't know what the stock plug
          gapp on those DOHC 3.4 engines are.
            according to alldata a 97 LQ1 uses 41-919 gapped at .045
            • tommyz34
              • Mar 2009
              • 3
              i have a 95 mc z34 with 3.4dohc has 111,000 on it i run rapidfire plugs no problem
              • GTP091
                • Jun 2005
                • 232
                I've been running Bosch platinum + 4 for three years with no problems... A few IC module issues and a dead CP sensor but plugs are fine.
                • W41duvernay
                  • Oct 2009
                  • 13
                  Reply 2 Robertstar
                  Sirs,
                  The splitfire S plug is equivalent to a .060s plug gapp. That's why a spark box needs to be run with it. Someone said that their using a platnum plug
                  in their Dohc v6. I had a problem w/platinum plugs in a DOHC quad 4. Be careful, I ended burning a hole in my header because I wasn't burning all of
                  the air/fuel mixture in the combustion chamber. All of those problems went away with the S plugs. They say their plugs w/last the life of the car.
                    I've run the #8's for years without a problem as well. I was told that they weren't in the right heat range though, and they tend to leak compression where the ceramic meets the metal so I was considering switching to NGK this year after having good results with them in customer cars.
                      Our waste spark system tends to trash Bosch plugs in a short amount of time because of the way it works. I bet you would be surprised if you put a different set of plugs in it.
                        Yup. Plus they are not usually the correct heat range for the car.
                        I replaced my friend spark plugs in his Jeep cause it was running bad, guess which ones they were? And guess what happened to 2 of the plugs? Ceramic shattered off... Hope his engine spit them out without chewing on them or getting caught in a valve... I wonder if they were the wrong heat range and messed up because of that? Usually though I think they are too cold...
                        But yes you need double platinum plugs with waste spark DIS.
                        • z34gtp383
                          • Sep 2009
                          • 37
                          plugs
                          i can only speak for myself, i had 2 z34's i just bought another one 2 months ago, and just picked up a 95 gp gtp. i have always used the bosch +4 plats. i never had a problem with them at all, i had cheap AC DELCOS at one point, i find the car wont idle as good as the plats. also along with good coil packs by MSD with taylor's 8.4 mm wire. this is what i have, you might wanna try this set up, it's all prefference bud,
                          In a quiet town full of chevy's, you can hear a FORD rust.
                          • z34gtp383
                            • Sep 2009
                            • 37
                            so what plugs do you guys use?
                            • SofaKingWeToddDid
                              • Jul 2009
                              • 785
                              read the previous posts to find out. (the two pages before your comment)
