Where to get a Cam belt tensioner
  • Fieroking
    • Aug 2007
    • 20
    I have had a failure of the Cam tensioner Hyd Assy. The rubber boot has a hole in it and leaks causing a skip of the Cam Timing belt. Does anyone know were I can get a new one? One one seems to have this parts any more!
    Help Please!
    Joe Sokol
    1996 3.4 (LQ1) in an 1985 Fiero
    check rockauto, part numbers:
    T41209. should come up with either an ACDelco or Gates tensioner... runs around $80...
    • Fieroking
      • Aug 2007
      • 20
      Thanks but wrong part
      Thanks for the reply. I looked up the part and it is the belt tensioner Pulley. What I need is the Spring Loaded Hydraulic actuator that keeps the pulley tensioned against the belt. Can't find a new one anywhere!
      Joe Sokol
      • jman093
        • Jul 2008
        • 164
        GM still makes it. Your dealer will have it or can order it. I bought one for $70 from a Chevy dealer a few months ago when mine went out. They even had it in stock.
        Jesse M.
        3x 1990 Turbo Grand Prix
        1987 Monte Carlo SS Aerocoupe
        • Fieroking
          • Aug 2007
          • 20
          Thanks
          Thanks for the info I will check with my local Chevy dealer. I had looked on the internet without any luck.
          Joe Sokol
          • Schurkey
            • Apr 2007
            • 339
            Hydraulic assembly???
            The one on my engine is spring-loaded. There's some oil in it, but it's not there to provide hydraulic pressure.
            First Guess: Something else is wrong.
            (I'll have to look at the service manual on this...seems very odd.)
