stalling a nd missing
  • billabong9687
    • Apr 2012
    • 16
    Just bought my 92 z34 with a 284.
    It seemed to have a miss at idle and sometimes took a while to start.
    Also had a hesitation during the power band. Trying to fix the startung problem I didnt hear the pump running, so I replaced it at 116k miles with an a/c delco pump. and filter. The in tank sock was black, and the filter seemed clogged, it helped with how fast the car started but still had a slight miss.
    So I pulled a plug out of it and found ngks in it.
    I recall from my last z that they seem to like nothing but delco plugs and wires, so I swapped the plugs for oe delco coppers.
    The power seems much smoother and the stalling is almost gone. Shifter into second seems much more powerful as well.
    I figured I would share my findings..
    1992 z34 284 Stock Torch Red
    2004 saturn ion redline: harrop tvs 1.3L s/c
    26 lbs of boost. Not so stock
    yeah, GM DIS is pretty picky about what plugs it plays well with, so Delcos were probably a pretty good choice, though i would have went with the platinums recommended for later LQ1s, or maybe the iridium equivalents, assuming there are any.
    • 88GTRacer
      • Sep 2005
      • 41
      I'd recommend the Delco rapidfires. 88GTRacer
      Sent from my BlackBerry 9900 using Tapatalk
        I use Rapidfires. I was actually considering trying a set of NGK V-Powers because I've had 3400's run great on them.
        • Dave96z34
          • Apr 2005
          • 624
          Auto lite copper core plugs iv found work best N/A and with boost or with an MSD box.
