DOHC Stall at 3000 rpm
  • gcarson114
    • Nov 2005
    • 9
    Our 92 GP 5-speed 3.4 will not accelerate past 3000 rpms in all gears. I think I have tried and replaced everything!!! Is there a solution I am missing?
    Is it hitting a rev limiter or does it just not go past 3k? Is it setting any codes? Have you messed with the computer or wiring before it started doing it?
    • gcarson114
      • Nov 2005
      • 9
      No codes are set and it misfires or stalls at exactly 3000 rpms.
      • dohc nut
        • Jun 2010
        • 18
        Check backpressure, or unbolt front of cat and run car to see if any improvement this sounds like a possible plugged catalyst.
