fuel pump output
  • dohcfiend
    King Chalupa
    • Jan 2004
    • 2351
    fuel pump output
    what is the fuel pressure in these cars be4 it hits the fpr?
  • brian89gp
    • 554
    roughly 45psi
    • dohcfiend
      King Chalupa
      • Jan 2004
      • 2351
      i am not sure about that. isn't it 45 after the fpr? i am referring to the pressure in the line. it's gotta be at least 55 at the minimum.
      • brian89gp
        • 554
        from the pump to FPR its near 45psi, from the FPR to tank its near 0psi.
        • Juglenaut
          • 1130
          The only pressure that is retained is on the inlet line going into the rail and incliding the rail, after the rail it goes back into the tank at less than 4-5 psi.
          my fuel rail maintains a psi of 35...and around 50psi on the fuel inlet line.
          If the return line has a kink or is plugged then pressures are directly affected coming in from the inlet.
          On a full tank pressures can be slightly more.
          I am back
          Mechanical/Service Technican
          • dohcfiend
            King Chalupa
            • Jan 2004
            • 2351
            ok thanx.
