95 GTP Transmission Noise Help (Video)
  • grandregal
    • Jun 2015
    • 2
    Hi guys,
    I recently purchased a 1995 GTP with the LQ1 and 4t-60e. The car sounds like it has a bad exhaust leak but I noticed the noise is only present in drive gears and worse under acceleration. I can rev it park or neutral and there is no exhaust leak sound. The trans shifts fine and fluid is clean but the noise is very loud and I would like to fix this before I need a new trans. Would this be a torque converter or flex plate problem? Any insight would be helpful. Thank you!
    - John
    Noise in drive with park brake set:
    Under Acceleration:
  • Schurkey
    • Apr 2007
    • 339
    Engine torque playing games with the exhaust system?
    Broken/damaged engine mount leading to excess engine rock--which then flexes the exhaust pipe-to-manifold joint?
    • grandregal
      • Jun 2015
      • 2
      Thanks for the reply Shurkey
      Is there any way the trans or torque converter could be making this noise? Is there a method I could use to rule them out?
      • Schurkey
        • Apr 2007
        • 339
        Sure. Trans or converter could make noise. Very unlikely. Check exhaust system first.
