Need to know
  • jdoutlaw5150
    • Oct 2015
    • 7
    Need to know
    Can I replace a 3400 SFI with a 3.4l dohc in my 03 Alero or with a 3800 supercharged what all would I have to move or change thank u for time and consideration in this matter
    Sent from my 831C using Tapatalk
  • Schurkey
    • Apr 2007
    • 339
    How well can you weld and fabricate?
    Overall,not my first choice for engine swaps.
    • jdoutlaw5150
      • Oct 2015
      • 7
      No welder but am ok at it
      • jdoutlaw5150
        • Oct 2015
        • 7
        What would you recommend
        • jdoutlaw5150
          • Oct 2015
          • 7
          I'm OK at it but don't have a welder on hand I already pulled 3800 supercharger on it and headers but what would you recommend
          • jdoutlaw5150
            • Oct 2015
            • 7
            Should I use the 3.4 liter DOHC I've built a lot of classic muscle but this is my first transverse motor don't know if I should go with a supercharger or turbo
            • thetruckster
              • Aug 2015
              • 9
              I agree about the 3.4 DOHC. I had one and wasn't impressed.
              It's obviously a taller engine and hugely expensive! Every OHC engine I've owned are expensive!
              Personally, I'd leave the 3400 in the Alero and just build it!
              Ben Lujin
              • jdoutlaw5150
                • Oct 2015
                • 7
                So half way there motor is in mounts made sensors wired adjusting header now to swap pcm and bum how can I get a pinnout for 03 alero bcm
                • Dave96z34
                  • Apr 2005
                  • 624
                  I don't know if your engine cradle has all the proper mounts for a LQ1. Post a pic of one and all let you know if it will bolt up or not. But I'm betting the rear mount is missing in a 03.
                  • jdoutlaw5150
                    • Oct 2015
                    • 7
                    I put in a l67 series 2 I've made new mounts have it in but need wire diagrams for the ecu plugs on the stock 03 alero 3400 sfi so I can wire it to a 97 or 98 grand prix 3800 sc ecu
