96 dohc vacuum diagram
  • dohcfiend
    King Chalupa
    • Jan 2004
    • 2351
    i don't know about the newer bodies but the older ones it was right beside the hood latch.
    Can some1 snap me a pic of that diagram?
  • dykz34
    • Jan 2004
    • 793
    Which ones are you having trouble with? I can possibly help you out.
    • dykz34
      • Jan 2004
      • 793
      Here's a picture of a 97 motor... the only lines that aren't hooked up are: brake booster, and the vacuum ball line which is right next to the brake booster. Not pictured is the PCV which uses the nipple on the side of the plenum below the intake arm mounting.
      • dohcfiend
        King Chalupa
        • Jan 2004
        • 2351
        i need all of them. i am putting a 96 motor into my 94 lumi and i don't have a 96 diagram. i really don't think it matters a vacuum port is a vacuum port? but i will make an effort to get everything to the appropiate ports within reason.
        judging from the pic it appears the only ones left is a connection to the vacuum modulator on the tranny, and the connection for the purge/accessory connection.
        • dohcfiend
          King Chalupa
          • Jan 2004
          • 2351
          cmon guys i know some1 has a vacuum diagram. hey dyk, can u put up tha pic again.
          also, I have the pcv hooked up and the connection to the front valve cover.
          • dykz34
            • Jan 2004
            • 793
            Here you go homeslice:
            • dohcfiend
              King Chalupa
              • Jan 2004
              • 2351
              appreciate it. got it saved too. 2 connections left. the vacuum modulator and the accessory connection. u have any idea what that port next to the brake booster goes to?
              • dykz34
                • Jan 2004
                • 793
                The smaller nipple next to the brake booster line is for the vacuum ball in the fender that is used for HVAC, cruise, etc.
                • dohcfiend
                  King Chalupa
                  • Jan 2004
                  • 2351
                  sweet that is the accessory connection i was referring to. so where does the vacuum modulator on the tranny connect?
                  • dykz34
                    • Jan 2004
                    • 793
                    I dunno... 96's didn't use that.
                    • dohcfiend
                      King Chalupa
                      • Jan 2004
                      • 2351
                      didn't know that. perhaps i will set it up like the my setup then. on my motor there was a t in the vac line for the charcoal cannister purge valve and that was for the accessory connection.
                      perhaps i will do that again and use the connection next to the brake booster to go to the vacuum modulator.
                      Do u think that will work ok?
                      • dykz34
                        • Jan 2004
                        • 793
                        The CCP on the 97 motor is the two black boxes that are bolted above the fuel rail. They draw vacuum from the TB. For the modulator on the tranny, I would just use a T-fitting on the accessory line to split it.
