Will these injectors work in a 91 3.4L DOHC?
  • grandprixgtp_91
    • Nov 2003
    • 758
    i am looking on ebay for new injectors but nobody has any for a 91 3.4L dohc but i found these they are for an earilier style 3.8l
    http://cgi.ebay.com/ebaymotors/ws/eB...category=33554
    will they work?
    if not how about these?
    http://cgi.ebay.com/ebaymotors/ws/eB...r4_PcN__Stores
    or these (3.1 , 3.4 single cam)
    http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?
    ViewItem&item=7934214816&category=33554
    or these 3.8 camaro
    i dont care about extra performance, it is only for basically a stock engine, i dont want any of them that will Under-fuel the engine i would rather get a little more performance than ruin the engine because there is not enough fuel. actually since they are all close to the same price if they all will work which one will give a little more performance? thanks for the help.
    Jake
  • grandprixgtp_91
    • Nov 2003
    • 758
    RE: Will these injectors work in a 91 3.4L DOHC?
    if anybody has an answer i need it asap, i need to buy injectors right away, the engine has 0 balls and hardcore shit fuel mileage (370 km to a tank of gas, mostly highway)
    Jake
    • dohcfiend
      King Chalupa
      • Jan 2004
      • 2351
      i have a set of 97 dohc injectors f/s. i know the 3100/3400 are 17's i believe. too small you have 23lbs. 3.8's are probably 19 or 21 but not sure. i can sell you my set for $60. also i have 4 injectors from a 94z at $7.50 a pop and 6 lt-1 injectors which are 23's as well for $2.50 a pop but they are untested.
      • grandprixgtp_91
        • Nov 2003
        • 758
        are the 97 injectors tested? do u know how many miles are on them?
        Jake
        • dohcfiend
          King Chalupa
          • Jan 2004
          • 2351
          yep they ran fine be4 i went to 30lb ford injectors. i didn't look at the odometer of the car so i am not sure. but they are clean if i had to guess 60k. also i have heard rumors that the newer injectors cure something referred to as "phantom stalling" on the earlier cars.
          • grandprixgtp_91
            • Nov 2003
            • 758
            http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
            Would these work in my car?
            Jake
            • napatiger
              • 490
              how are the 97 injectors different from the 95 for the DOHC?
              95 MC Z34 Black
              • grandprixgtp_91
                • Nov 2003
                • 758
                ill have to get back to on the 97 injectors, i might take them, how much more perormace did you get with the 30lbs injectors, and how did your gas mileage get affected?
                Jake
                • grandprixgtp_91
                  • Nov 2003
                  • 758
                  So im guessing these would work? there for my brother, i might get those 97's for my car though.
                  Jake
                  • dohcfiend
                    King Chalupa
                    • Jan 2004
                    • 2351
                    those accel injectors should work. i don't think there is a difference between 97 and 95 injectors. the 30's i have are mainly for 2 reasons. i am going to a 75mm tb with ported upper and lower intakes. and later i plan on going turbo(not to mention the n20 system).
                    i wouldn't recommend them unless you are heavily porting,boosting or spraying the engine. i plan on all 3
                    • wdowey
                      • Nov 2003
                      • 16
                      ive had the 21lbs Accel's in my car for over a year now and havent had a problem yet...
                      got all 6 from summit racing for under $200..
                      • wdowey
                        • Nov 2003
                        • 16
                        oh yeah, they worked better when i put the Accel coils on too..
                        92 z34
