spring swap need help
  • dohcfiend
    King Chalupa
    • Jan 2004
    • 2351
    i was talking to some1 about lq1 valvesprings and he said he swapped valvesprings on a set of heads for some1.
    anyway he put 94-95 springs on 96-97 heads. will that work? i told him that the lifters on a 96-97 are 33mm vs the 35mm ones on a 91-95. he said that didn't matter. is that true?
    lastly, do you have to swap seats or any other components? also what are the specs on the 94-95 vs the 96-97 springs. i was told the 96-97 springs are the weakest set and the 94-95 was the strongest set of the lq1 production run. i would look it up in the specs but it only list the 1st gen lq1 specs instead of all of them like it used to.
  • dohcfiend
    King Chalupa
    • Jan 2004
    • 2351
    RE: spring swap need help
    bump
    • dohcfiend
      King Chalupa
      • Jan 2004
      • 2351
      any1?
