Please help me understand cam specs
  • joey b
    • Feb 2004
    • 75
    I found the cam specs, but I'm unsure how to read them.
    Lobe Lift (Intake)
    0.370 @ 108° Crank ATDC
    Lobe Lift (Exhaust)
    0.370 @ 115° Crank BTDC
    Timing Reference Set Position with Camshaft Timing Flats in Clamped Position-Right Bank
    TDC-1Piston Exhaust Stroke +/- 2° of Crankshaft
    Timing Reference Set Position with Camshaft Timing Flats in Clamped Position-Left Bank
    TDC-4 Piston Exhaust Stroke +/- 2° of Crankshaft
    I can easily see the max lift and what that means. However, what I am unable to understand is at what point the Valves are opening and at what point they are seated again.
    92 cutty auto with a 97 3.4
    93 convert with 3.4
    • 9186
    RE: Please help me understand cam specs
    The durtations aren't listed in what you are showing, so there is no way to describe it to you. But the max lift is listed as .0370" @ 108º Crank After Top Dead Center, where TDC is the point when the #1 cylinder is at the top of its rotation. BTDC is just Before TDC.
    • joey b
      • Feb 2004
      • 75
      so how many degrees are the duration? At what point do the valves begin to open and at what point are they seated?
      What do the second series of specs tell us?
      93 convert with 3.4
      • Synestral
        • Mar 2005
        • 53
        Re: RE: Please help me understand cam specs
        That information isn't in the cam specs you posted.
        That is just how to find tdc in reference to which cam you're setting.
        92 Lumina Z34
        Found coolant in the oil and metal in the filter.
        Also found a home in the engine compartment for a turbo and intercooler
        Some pics at CarDomain
        • joey b
          • Feb 2004
          • 75
          RE: Re: RE: Please help me understand cam specs
          Does anybody know the specs for the duration and at what point the valves are starting to open and when they are seated?
          93 convert with 3.4
          • your_I.D.
            • Mar 2005
            • 337
            That would be IVO (int valve open),IVC (close),EVO(exhaust valve open) and EVC (close). No one seems to know it. Or know lobe centerline to figure it out. Info at this link will explain cam technology and degreing. You'll have to read it a few times. Theres alot of info to absorb.http://www.iskycams.com/pdfcatalog/2004-05/page205.pdf
            1997 Z34 Monte,: testing 4 exh cam\'s, RSM STB, K&N, Eagle077 245/40/ZR18 Nitto Extreme
