knock sensor questions
  • dohcfiend
    King Chalupa
    • Jan 2004
    • 2351
    how do they function? are they powered or do they just send an output signal to the ecm?
    lastly, if all they do is send a signal and if say u have a 91-95 ecm system with a 96-97 engine, could u splice the second one in paralell to the other one and they both function correctly?
  • pepsi_coke
    • 288
    http://www.60degreev6.com/modules.ph...rtid=32&page=1
    This sensor is screwed into the block and detects detonation. If knocking or pinging is sensed the ECM will retard the ignition timing to prevent serious engine damage. Depending o­n the strength of the knock the ECM will pull a set amount of timing very fast and then slowly reduce the knock retard back to 0 or more knock is encountered, whichever happens first.
    The circuitry in the knock sensor pulls the +5V input voltage down to 2.5V, the knock sensor then produces an AC voltage that rides the 2.5V DC voltage. A knock will cause a voltage spike in AC voltage that oscillates about the 2.5V bias, if the spike is above 3V it is considered knock.
    New member of 200,000 mile club as of May 16, 2005
    • dohcfiend
      King Chalupa
      • Jan 2004
      • 2351
      so in other words probably not. thanx.
      • dohcfiend
        King Chalupa
        • Jan 2004
        • 2351
        last thing. can i pull the wiring back and hook up the front one instead of the rear one and everything still function correctly?
        • your_I.D.
          • Mar 2005
          • 337
          I dont see why not. Are the part # the same?
          1997 Z34 Monte,: testing 4 exh cam\'s, RSM STB, K&N, Eagle077 245/40/ZR18 Nitto Extreme
          1972 3/4 ton 4X4 longbed, built 350, 400 auto, 6\" spring lift, 35\" AT/BFG\'s, dana 60 front axle, 14 bolt gm w/detroit locker 4.56 gears. My ricer smasher
          • Kohburn
            custom fab-whore
            • Apr 2005
            • 165
            yeah you can use one or the other
            if you exhaust routing going out the back then using the front sensor would be benefficial to avoid exhaust related false readings
            • dohcfiend
              King Chalupa
              • Jan 2004
              • 2351
              hmmmmm. very nice. i like. thanx guys.
              • dohcfiend
                King Chalupa
                • Jan 2004
                • 2351
                sorry to bring it back up but i can't believe it. i was f@@king right. i was helping a bud of mine with a lt-1 harness and it had 2 knock sensors and they were wired paralell to 1 wire going to the ecm. YAY
                • farmerz24
                  • Feb 2004
                  • 361
                  so then dual knock sensors. this would explain why i always pop my rear pistons from det. and not the front. i may do this aswwell.
                  • grandprixgtp_91
                    • Nov 2003
                    • 758
                    the only problem ive had with using the 96/97 sensors , is you need new connectors and the 91 connectors have resistors in them and the 96/97 ones dont so the ecm sets the knock retartd to max, so with an early style ecm you would need the early stlye knock sensor and connector.
                    Jake
