cheap cold air intake
  • birdman
    • May 2005
    • 274
    ive found out that the honda civic cold air intake that you can get at any autozone for around $40 will fit our cars perfectly if you cut about 3 inches off the end. they are in a orange package and have sone stupid writing on it. i got mine off a friend for $5 including air filter. ill post pics if anyones intrested.
    92 Lumina euro 3.4 DOHC 139,XXX miles
  • RednBlack
    Wood Hippie
    • Mar 2004
    • 2795
    Our cars? I doubt it... Might fit a couple. I'd like to see the pics.
    • goatman
      • Jun 2004
      • 151
      It works, I did it to mine last summer. Just get that, one of the rubber connecter things, and a K&N cone filter, works just fine.
      1993 Lumina Z34 - Broke Yet Again
      What the flip Uncle Rico!?!
      • pwmin
        • Aug 2004
        • 394
        91 GTP HM-284 GONE :(
        98 Spawn of Satan (L67 Regal)
        87 V10 SM-465/Mild 350
        06 Cobalt SS/SC GONE :(
        • RednBlack
          Wood Hippie
          • Mar 2004
          • 2795
          So where does the "Cold" air come from? Surely not from under the hood.
          • birdman
            • May 2005
            • 274
            heres some pics. i know its not a real cold air intake but its better tham stock and sounds much better. im gonna try and build a heat shield to keep it cool. if the pics dont work ill try again, im not quite sure how to post pics
            [img]C:\Documents and Settings\Administrator\My Documents\My Pictures\My Ride\dsc182[/img]
            [img]C:\Documents and Settings\Administrator\My Documents\My Pictures\My Ride\dsc183[/img]
            [img]C:\Documents and Settings\Administrator\My Documents\My Pictures\My Ride\dsc185[/img]
            • birdman
              • May 2005
              • 274
              i think i got it this time, sorry the pics arnt the best but it gives the general idea.
              • vsop4me3.1
                • 482
                you guys should try building some sort of a box to keep the heat out. I know when I had a set up like that on my GP, beit a 3.1 it ran like shit.
                I wish 10% of the people on the road knew how to drive
                • Kyles93Z34
                  • Dec 2004
                  • 347
                  All and all, how long did it take you to remove the stock box and replace with the new intake? I am thinking about doing this but am not very mechanicaly inclined. Do you have to drill any holes or anything of that sort. And will it increase any performance on a stock car.Thanks.
                  Kyle
                  P.S. Is that a Lumina Z34 in the pics?
                  1992 Lumina Z34
                  5 Speed
                  Autozone civic intake
                  Ultra White lights
                  FFP Dogbone mount
                  125k miles
                  2.5 inch Magnaflow catback from Magnaflow cat
                  60degreeV6.com Custom Chip
                  • birdman
                    • May 2005
                    • 274
                    it'll take 30-45 min. to do. you have to cut about 3-4 inches off the long end and drill a hole for the Intake Air Temp. sensor. fairly stright forward. seems to give mabey 5-8 seat of pants HP. also give it a real good sound under acceleration.
                    And its a 92 EURO 3.4
                    • RednBlack
                      Wood Hippie
                      • Mar 2004
                      • 2795
                      That is simply a cone filter. There is no "Cold" air involved. Cold air comes from outside the engine compartment.
                      • Kyles93Z34
                        • Dec 2004
                        • 347
                        Is this that sensor? How large do you think the hole is? Thanks again.
                        Kyle
                        1992 Lumina Z34
                        5 Speed
                        Ultra White lights
                        FFP Dogbone mount
                        125k miles
                        • birdman
                          • May 2005
                          • 274
                          its the sensor on the back driver side of the origonal air box. i put on the bottom of the tube near the filter. and like i said before i know its not a true cold air intake but im going to build a heat sheild along the bottom and engine side to keep it cooler. there are also other things to keep in mind. like the less restriction, and less turbulance. still a fairly good upgrade for the price. look one up on www.rsmracing.com big price difference for basically the same thing.
                          • Kyles93Z34
                            • Dec 2004
                            • 347
                            Thanks
                            Kyle
                            1992 Lumina Z34
                            5 Speed
                            Ultra White lights
                            FFP Dogbone mount
                            125k miles
                            • birdman
                              • May 2005
                              • 274
                              that hose you circled was to connect the plastic tube that used to plug in the top of the intake tube to the existing fitting on the new intake.
