oil cooler
  • napatiger
    • 490
    oil cooler
    In all the shop books it shows that the LQ1 has an oil cooler, mine does not have one, whats up with that? Should I get one? and is it as simple as ordering the parts and install?
    Adapter plate
    cooler lines
    cooler radiator
    Also, do most people think that the stock tranny cooler is pretty good or would you upgrade? I have a new tranny in there now with 0 miles.
    95 MC Z34 Black
  • Mitch DOHC
    • Jan 2004
    • 261
    RE: oil cooler
    you do not need one.... 94+ did not have them.... and sence yours is a 95 the would explane why it isent there
    1994 Cutlass Supreme Convertible 3.4 DOHC
    1969 Oldsmobile 442
    1997 Chevy Tahoe
    http://members.cardomain.com/mperkins442
    • dohcfiend
      King Chalupa
      • Jan 2004
      • 2351
      RE: oil cooler
      i think an oil cooler can always be beneficial. they came in 91-93 models only. i don't know whether they were standard or an option. the only 2 reasons i can think of for the 94+ cars not having them was either gm cutting cost or the 91-93 models radiators were too inefficient, b/c the rads in 94+ are bigger.
      only drawback is the stocker is a liquid cooled cooler and you'd be alot better off with an air cooled oil cooler.
      parts will be adapter plate, hoses, and 2 fittings. one scews into the block and the other replaces that cover on your w/p area that alot of owners mistake for the thermostat housing.
      • series8217
        • Dec 2004
        • 387
        I have never seen a 91-93 motor without one.
        There's nothing bad about a liquid cooled cooler. These just suck to flush out. I wouldn't even bother with a used one. Who knows whats in it? GMPD has 'em cheap enough.
        • Jaysin
          • Jan 2005
          • 55
          Where does the coolant hook in. I know one side comes from the block but I cant find where it comes from on the other side. The engine is in a 95 Monte. Thanx
          • dohcfiend
            King Chalupa
            • Jan 2004
            • 2351
            if u look in your wp area there is a removable cover held in by 2 bolts. it has a pieces pointing down on the 94-97's but it is solid. on the oil cooler motors, it is not solid and there is a coolant port there.
            • Jaysin
              • Jan 2005
              • 55
              Gonna have to give it a look. I have that cover from the 91 engine. It should bolt right up I think. It will be nice to have the cooler functioning!
