cooling problems
  • j-13gtp
    • Jul 2004
    • 60
    cooling problems
    Ok guys this past week ive been having problems with my radiator, leaking whenever it wants to. Its quit here recently, but when I got off work I came out to my car and started it up, the engine was still warm from being driven 3hrs before but outside was like 45 degree's. I get out the parking lot and the temp meter on the dash rise fast; I turned the heat full blast no warmth coming from the vents. After a short time the heat comes on and the temp goes down way down. But this doesn?t explain why for a whole 5minutes the temp was near 210 and then drops to 150 degrees.
    The question is, do I have a problem with the thermostat or something else.
    Maybe Im just imaging things :wtf:
    1995 3.4 DOHC Grand Prix gtp
    cold air intake, high flow cat, dynomax mufflers.
  • RednBlack
    Wood Hippie
    • Mar 2004
    • 2795
    Thermostat sticking
    • corning_d3
      • 13
      Thermostat or low coolant.. I've even had air in the system cause that.
