waterpump redesign
  • dohcfiend
    King Chalupa
    • Jan 2004
    • 2351
    waterpump redesign
    when putting a rebuilt engine together i decided to spring for a new waterpump and with it came a TSB showing that it is completely redesigned over the factory ones.
    i figured i would let everyone know in case any1 was rebuilding their engine or debating on a new waterpump.
    i am assuming it is better than the old design.
  • GPonurA
    • Feb 2006
    • 1
    I hope you are not referring to this style pump. http://60degreev6.com/showthread.php?t=31924 If so, then enjoy your new overheating problem because this design does not work on the DOHC's. I have personal experience with this issue. Go back to the old design.
    • Rhedalert
      Dr. Feelgood
      • 1574
      whoa, that "redesigned" one has an impeller that many import waterpumps use (usually driven off the timing belt)
      Brian
      3400 SFI V6, 4T60e
      • dohcfiend
        King Chalupa
        • Jan 2004
        • 2351
        i see i may have to take this TSB to the dealer to validate if in fact gm did redesign the impellers. thanx for the heads up.
